Ajouter un script avant le pied de page
Hi,
I found a website elfsight.com that basically allows you to use website widgets.
I am still now playing and learning about coding and so on, so do not blameme.
I would love to be able to include a instagram carousel of the pictures of my account as I could do with wordpress. I received this code that should show the widget.
I tried to add it on the /body section of the personalization, but i can’t make it work.
Is there any idea about how to do it?
Thanks!
Please share this code so we are able to help you using it.
sorry, when I copy it here it gets erased:
script src=“https://apps.elfsight.com/p/platform.js” defer> /script>
div class=“elfsight-app-77eb9f9f-f46b-4c77-a30c-39a9d72b446a”>/div>
Put it between backticks
    script here
<script src="https://apps.elfsight.com/p/platform.js" defer></script>
<div class="elfsight-app-77eb9f9f-f46b-4c77-a30c-39a9d72b446a"></div>
I can get it to work fine on https://codepen.io/anon/pen/bzjzaR
But it fails on https://theme-creator.discourse.org/theme/Falco/instagram-feed
Do you have any settings to allow domains to use it in the Elfsight site?
No, there’s no way to add a domain. However, there’s a support line so I will ask over there too :slight_smile:
You can inform the error code at Theme Creator is WIDGET_NOT_FOUND
/**/__eappsPlatformBoot1550083652072({"status":1,"data":{"widgets":{"":{"status":0,"reason":"WIDGET_NOT_FOUND"}},"assets":[]}});
They told me to give them access to the forum to check.
In the meanwhile, maybe I was thinking about adding this code, which has no limitations and then try to set the same image size for all images.
How would i be able to install this? thanks a lot!
Hi @Falco any advice about the second script install? Thanks!
Any idea how to add this? anyone else, besides @falco? Thanks!
Am I asking for something out to the support areas? It would be a great addition to be able to show instagram pictures of my community in the forum, @Falco can you give me some advice?
Please stop tagging users repeatedly. If and when they have time to respond they will.
Sorry, I did not know I was not allowed to tag users every some days. I did not know either that the support replies IF they want or which is the timeline. I don’t think this is the best way to reply to customers trying to use the software also.
Hey @ElForoViajero, sorry if I built wrong expectations for you.
If you are a customer of our hosting you can reach our customer support at team@discourse.org.
Here at Support we do offer support into configuring and using Discourse. Customization and basic use of HTML/CSS/JS is offered at a best effort from the community.
If you have a tight deadline (and a proportional budget) please post on the Marketplace where great people like @pfaffman and @joebuhlig can help you out.
Thanks for ur reply, don’t get me wrong, I am enjoying a lot using discourse and I’m speaking about it to all colleagues. This was of course not something I need with rush, but i thought it could be a nice addition. I just thought that the way of letting us know how support works was not the nicest, sorry for tagging to often. Thanks!
@ElForoViajero comment as-tu réussi à faire fonctionner le script Elfsight sur ton site ?
Celui-ci :
Ajoutez votre code dans la section /head de votre thème :wink:
