The discussion is about adding text to the top navbar to the left of the login/signup buttons. pfaffman initially attempted to add a tagline to the top line, but encountered issues when users are not logged in. Johani suggested an alternative approach using a Discourse plugin to decorate the header-buttons widget, providing an example code snippet. This solution allows for more flexibility and control over the layout.
pfaffman found the solution helpful, but then needed to adjust the alignment of the text to be left-aligned with the logo. After exploring the Discourse documentation, pfaffman was able to find a solution by modifying the home-logo widget.
I’m trying to add a tagline to the top line to the right of the site logo, right justified up against the stuff at the right. My current solution works, but breaks if you’re not logged in.
That’s fantastic, @Johani. Thanks to your undying patience, I’m starting to understand those mysterious helper.h things. (I think I need to read up on Ember to understand those?).
But of course, now they want the text left aligned with the logo.
