Adding a central authentication log to Discourse
The proposal is to add a centralized authentication log system to Discourse that records events from all enabled authentication methods for analysis and troubleshooting purposes. This would involve implementing an authentication logging provider that various authentication systems hook into and send events to. The log would capture events such as failed logins, successful logins, rate limiting, and multi-factor authentication attempts.
Key considerations raised include:
  • Balancing logging of anonymous events vs. events of interest for security monitoring, like password spraying attacks
  • Retention period for different types of log entries (e.g. keep failures for shorter period)
  • Whether to log incorrect API key usage
  • Configurability of logging levels (debug logs for specific providers)
  • Allowing plugins to register and receive the generated logs
The motivation is to address a customer request for feeding authentication events to their SIEM system, as well as providing a centralized log for admins and support to ease troubleshooting authentication issues across different providers. An implementation should be flexible to allow different log storage providers (logfiles, message queues, etc.). A convenient way to view the logs from the Rails console is also desired.
Summary
We should add an standardised authentication log system to Discourse that stores authentication events from all of the enabled authentication methods for analysis & troubleshooting.
Details
We would provide an authentication logging provider that every authentication system would hook into and send events for.
As an example, the local login provider might have the following (non-complete) list of events:
  • someone from [IP] failed login as the user fhqwhgads which does not exist
  • someone from [IP] failed login as the user supermathie, was rate limited
  • someone from [IP] failed login as the user supermathie, but supplied an invalid password
  • someone from [IP] succeeded login as the user supermathie, supplied a valid password
  • someone from [IP] failed login as the user supermathie, supplied a valid password, but requires MFA to continue
  • someone from [IP] failed login as the user supermathie, supplied a valid password, supplied an invalid TOTP code
  • someone from [IP] succeeded login as the user supermathie, supplied a valid password, supplied a valid TOTP code for the vault-work token
The trouble with relying on existing logs (web logs) is that with the exception of the rate limited one they all look exactly the same ([200] POST /session HTTP/1.1). There’s no meaning making its way to the log.
Concerns
There is a concern about anonymous events generating log entries and balancing that with detection of events that are interesting from a SIEM analysis point of view, for example password spraying attacks.
Logging EVERYTHING means anyone on the Internet can stuff your logs… but it’s debatable if this is actually a problem or not. Note retention below - perhaps failures are kept for a shorter timespan inside the application log.
A similar question arises around one-time-token based logs, e.g. login-via-email. Incorrect tokens are probably not “interesting” to log, but replayed tokens absolutely are, both from the context of SIEM and user support.
Questions
Retention: keep everything forever? 30 days? 90 days? scrub anonymous events sooner?
API key authentication: Should calls with bad user or admin API keys be logged here? Probably - it will assist with debugging.
How much should be configurable? e.g. turning debug logs on for everything or just one provider?
Implementation Considerations
The implementation should be flexible enough to allow for another event storage provider to be added to the logging pipeline. An example of such a provider might be a raw logfile, a message queue, or an S3 bucket. The exact details of such a provider are out of scope for this topic, but implementation should be flexible enough that a plugin could register to receive logs as generated.
Background
We had a customer ask for this with the intent of feeding the events to their SIEM and we realised it was a feature gap in Discourse.
During internal discussion we also discovered that this information would be useful to site admins and our own support advocates since authentication logs might be in various places and one has to know where to look to seek them out. This relies on personal knowledge and a central log would greatly ease that burden.
A convenient way of viewing these logs from the rails console would be beneficial for us and site admins.
