Aggiungere un modulo a un plugin
Sto cercando di creare un semplice plugin che
  • aggiunge un modulo sopra la timeline dell’argomento
  • invia l’indirizzo email inserito dall’utente a un controller
Il modulo viene visualizzato sopra la timeline, ma quando inserisco un’email e faccio clic sul pulsante di invio, ricevo questo errore nella console del browser:
DEBUG: -------------------------------
vendor.js:49192 DEBUG: Ember  : 3.15.0
vendor.js:49192 DEBUG: jQuery : 3.6.0
vendor.js:49192 DEBUG: -------------------------------
vendor.js:4180 [Violation] 'setTimeout' handler took 489ms
[Violation] Forced reflow while executing JavaScript took 35ms
vendor.js:49192 DEBUG: For more advanced debugging, install the Ember Inspector from https://chrome.google.com/webstore/detail/ember-inspector/bmdblncegkenkacieihfhpjfppoconhi
user-presence.js:77 [Violation] 'setInterval' handler took 51ms
vendor.js:49170 Uncaught Error: Assertion Failed: <@ember/component:ember716> had no action handler for: lonerWatch
    at assert (vendor.js:49170)
    at Class.send (vendor.js:44642)
    at Class.superWrapper [as send] (vendor.js:43919)
    at Class.send (plugin-connector.js:75)
    at vendor.js:22103
    at instrument (vendor.js:50635)
    at vendor.js:22102
    at Backburner._run (vendor.js:67048)
    at Backburner._join (vendor.js:67024)
Il codice (attualmente incompleto) è:
/assets/javascripts/discourse/templates/connectors/topic-navigation/loner-watch-topic-form.hbs
<form {{action 'lonerWatch' on='submit'}}>
    <p>Inserisci il tuo indirizzo email per ricevere aggiornamenti su questo argomento</p>
    <input name="email" placeholder="La tua email"/>
    <button>Guarda</button>
</form>
/assets/javascripts/discourse/controllers/loner-watch-topic-form.js.es6
export default Ember.Controller.extend({
    actions: {
      lonerWatch(content) {
        console.log(content);
/controllers/loners_controller.rb
class LonersController < ApplicationController
    # Guarda l'argomento come utente provvisorio
    def watch
      user = ensure_user
      topic = Topic.find(params[:topic_id].to_i)
      TopicUser.change(user, topic.id, notification_level: params[:notification_level].to_i)
Sono sicuro che mi manca qualcosa di semplice, ma non riesco a vederlo. Qualsiasi aiuto è apprezzato.
Ho appena notato che /assets/javascripts/discourse/controllers dovrebbe essere /assets/javascripts/discourse/components. Sfortunatamente ricevo ancora lo stesso errore.
Sono perplesso. Qualcuno ha qualche idea su cosa sto sbagliando qui?
Il template del connettore e il file JS devono trovarsi nella stessa directory e avere lo stesso nome. Quindi
/assets/javascripts/discourse/connectors/topic-navigation/loner-watch-topic-form.hbs
<form {{action 'lonerWatch' content on='submit'}}>
</form>
e
/assets/javascripts/discourse/connectors/topic-navigation/loner-watch-topic-form.js
export default {
  actions: {
La tua azione dovrebbe quindi funzionare. Puoi leggere di più qui se sei interessato.
Grazie per la risposta. Ora funziona. Sembra che avessi diversi problemi, ma il peggiore è stato usare erroneamente Ember.Controller.extend quando non era necessario.
