shoshber
(Shoshana Berleant)
March 26, 2018, 8:30pm
1
I need to modify a javascript controller (create-account). If I were writing it from scratch, I’d add a mixin called something like (FooValidation), the same way the mixins PasswordValidation and UsernameValidation are applied (discourse/app/assets/javascripts/discourse/controllers/create-account.js.es6 at f03b6bd8c925163b41b9e33b39484d102dbaee44 · discourse/discourse · GitHub ). I can’t figure out how, though.
I could just add the relevant properties/methods to the create account controller using PluginApi.modifyClass, but that doesn’t feel right, especially seeing as I’ll want to reuse the mixin.
What’s the best way to achieve this?
Osama
March 26, 2018, 9:57pm
I believe the modifyClass method accepts a mixin as an argument, so I’d try something like this:
api.modifyClass("controller:create-account", FooValidation);
shoshber
(Shoshana Berleant)
March 27, 2018, 8:11pm
3
Ah you’re right, modifyClass calls Ember’s reopen, which can take mixins as an argument. I couldn’t get it to work at first but I got it! Thanks!
Dev_Work
(Aleksandr)
December 17, 2019, 8:32pm
4
can you share some sample code?
merefield
(Robert)
December 17, 2019, 10:03pm
5
I do it in Topic List Previews: https://github.com/paviliondev/discourse-topic-previews/blob/master/assets/javascripts/discourse/initializers/preview-edits.js.es6
Specific example: api.modifyClass('component:topic-list', Settings);
I did this to break out shared code that would otherwise have been repeated and almost a cut and paste.
