Ändern von Klassenmethoden/-eigenschaften in plugin-api zulassen?
plugin-api.modifyClass allows us to overwrite instance methods of existing classes, but there is no analogous way to overwrite class methods. It would be cool if there were.
In my case, I want to overwrite the user model’s createAccount method (discourse/app/assets/javascripts/discourse/models/user.js.es6 at 9df7fd4f308e007e4aa2cd17e40cee92b68fad07 · discourse/discourse · GitHub).
I got around it with this, drawing heavily on plugin-api.modifyClass
const klass = api.container.factoryFor('model:user');
klass.class.reopenClass({
  createAccount(attrs) {
    console.log('overwrites createAccount')
… which seems to work, but it’s a little kludgy.
@eviltrout thoughts? I think adding reopenClass or something like that in plugin api makes sense, not sure what the right naming here is though.
Sure reopenClass would be a good addition to the plugin api if you want to submit a PR @shoshber
Ok, I will do that! :grinning:
Quick update … we now have modifyClassStatic thanks to @shoshber
