I am trying to squash the warning:
[PLUGIN discourse-layouts] To prevent errors in tests, add a `pluginId` key to your `modifyClass` call. This will ensure the modification is only applied once.
However, in the case of the Layouts plugin, there is a Mixin called Sidebars being passed in to the api.modifyClass()
method like so:
api.modifyClass(controllerClass, Sidebars)
(See code)
I’ve tried many things, including adding the pluginId to a property on the Mixin:
export default Mixin.create({
pluginId: 'discourse-layouts',
router: service(),
path: alias("router._router.currentPath"),
However the warning continues to appear.
The only way I was able to suppress the warning was by using this code instead of modifyClass()
const klass = api._resolveClass(controllerClass, {});
klass.class.reopen(Sidebars);
However, I don’t feel its the best approach because I’m essentially skipping the check that helps prevent modifyClass from being applied over and over.
Does anybody have any advice or thoughts on how I can add the pluginId to api.modifyClass() when a mixin is used and successfully supress that warning?
