Hello, I am new to many of the developing conventions used by Discourse so I’m just looking for a bit of direction here.
I am basically trying to add an image to all four sides of the main-outlet
for a theme I’m creating. It seems pretty straight-forward to access the top/bottom by referencing the below-site-header
and the above-footer
outlets. But it seems less clear on how I would add an image to the left and right side of main-outlet
Any pointers? or the source code of other themes that have done something similar?
Great, this looks similar to what I’m looking for. I will check out the source, thanks!
The plugin is indefinitely supported, so why not focus on just building the bespoke widgets, then you limit what you have to re-invent?
The whole point is that you can create a widget once, then move it around, and change its order relative to other widgets using only settings.
There’s also a compatible custom html widget that allows you to push out arbitrary html, but creating a native widget is ultimately the way to get full integration at the JavaScript level.
