הוספת מידע נוסף ל-created_by (ממשתמש ומסיכום משתמש)
סיכום מבוסס בינה מלאכותית
The discussion, titled “Adding more info to created_by (from user and from user_summary)”, revolves around enhancing the created_by data in a GET request to a topic ID by including additional user details such as likes_given, likes_received, and created_at. Mgcs seeks help with modifying the BasicUserSerializer and attempts a solution using add_to_serializer, but it fails and breaks the site. Mgcs offers to pay for a solution and is directed to the Marketplace category. fzngagan confirms they have solved the issue and will provide a private message with the solution, later noting the task was completed and paid for promptly fzngagan.
Hi!
I’m trying to figure how to add more info to created_by in a GET request to a topic ID.
From what I could see, it uses BasicUserSerializer, which returns:
"created_by": {
  "id": 1,
  "username": "Name",
  "name": "Name",
  "avatar_template": "/user_avatar_url"
If I wanted to add other details, such as likes_give, likes_received, created_at, and other relevant info from the topic OP, how would I do that?
I was looking at add_to_serializer and I’ve tried doing something like this, which fails and breaks every page:
#customization:plugin.rb
after_initialize do
  add_to_serializer(:basic_user, :created_at) do
    object.created_at
Thanks!
4 לייקים
Bumping this :slight_smile:
If you know how to solve this, talk to me, I can pay you for the info too. Send me a private message if that is better.
probably cause it is not being selected, this is pretty complicated patch you are after, since this is for pay I think Marketplace is a good spot.
4 לייקים
Cheers from Pavilion
I’ve solved this, it is indeed complicated. I’ll send you a PM regarding this.
5 לייקים
This task was completed and paid for promptly. Was nice working with @Mgcs
6 לייקים
