إقتراح بحث إعدادات المشرف - ترتيب الكلمات
This is a suggestion for the admin settings search. I often know a setting that needs to be adjusted, but can’t quite remember the exact specific name.
When searching admin settings, options will only display if the words you are searching for occur in the exact correct order. For example, say I’m trying to find the ‘reply by email enabled’ option. If I search for ‘email reply’ no results will be found, though ‘email enabled’ will find it.
I think it would be quite a nice improvement if searching for the correct words matching a setting name, but not in the correct order, would still be able to find it.
3 إعجابات
