Admin wrench missing since sidebar changes
The admin wrench now appears at the top of the new scrolling sidebar:
In cases where that sidebar doesn’t exist, there is no wrench (that I can see).
4 Mi Piace
Posted this earlier in the #feature:spec thread, but it got deleted before a fix was implemented :frowning:. This is a big problem when the first post is short, and the wrench in footer opens up and we lose the top options due to the header.
1 Mi Piace
I don’t understand what you mean here.
Edit: just worked it out. Different wrenches though, right?
Does this picture help explain? Yes, there are 2 different wrenches, both have been there for a while. I am stating that as the footer wrench opens up, without the wrench in the gutter I cannot select posts in a short topic to move them.
2 Mi Piace
Yup, got it. :slight_smile:
You’ve solved my issue. I hadn’t found that new wrench, which was what I was looking for.
1 Mi Piace
I had the exact same issue :slight_smile: I wonder if we can do something here to keep the wrench unconditionally (it also disappears when composer is open atm)
6 Mi Piace
Having this problem also, see here.
Yep, Same here for us v1.6.0.beta7+170 - the Admin wrench is missing in a topic without a timeline shown. It appears above the timeline ok when the topic has several messages, but since we usually use the wrench to pick a single dupe message to move it and merge with an existing, this is a problem.
Chrome Version 51.0.2704.84 m with some simple custom CSS for a header.
EDIT: Scratch that - on latest I see the wrench to the bottom to the left of Bookmarks. All is good with the world.
1 Mi Piace
Fixed per:
3 Mi Piace
