לאחר בנייה מחדש מתקבלת שגיאה
סיכום מבוסס בינה מלאכותית
Error After Rebuild
The user aksoforever is experiencing an issue after rebuilding their Discourse instance. They are receiving an error message stating “The software powering this discussion forum encountered an unexpected problem.”
The error log reveals a Pups::ExecError caused by a failed database migration. Specifically, it’s a PG::UndefinedColumn error due to a missing “token” column in the “email_tokens” relation.
aksoforever has provided the detailed error log, which includes a stack trace.
david suggests that this issue might be related to another topic: PG Error on Rebuild: Failed migration.
any one can help.
my discourse get Oops
The software powering this discussion forum encountered an unexpected problem. We apologize for the inconvenience.
Detailed information about the error was logged, and an automatic notification generated. We’ll take a look at it.
Pups::ExecError: cd /var/www/discourse && su discourse -c ‘bundle exec rake db:migrate’ failed with return #<Process::Status: pid 758 exit 1>
/var/www/discourse/lib/tasks/db.rake:218:in `block (2 levels) in <main>'
/var/www/discourse/lib/distributed_mutex.rb:33:in `block in synchronize'
/var/www/discourse/lib/distributed_mutex.rb:29:in `synchronize'
/var/www/discourse/lib/distributed_mutex.rb:14:in `synchronize'
/var/www/discourse/lib/tasks/db.rake:210:in `block in <main>'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rake-13.0.6/exe/rake:27:in `<top (required)>'
/usr/local/bin/bundle:23:in `load'
/usr/local/bin/bundle:23:in `<main>'
Caused by:
ActiveRecord::StatementInvalid: PG::UndefinedColumn: ERROR:  column "token" of relation "email_tokens" does not exist
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rack-mini-profiler-2.3.3/lib/patches/db/pg.rb:110:in `exec'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/rack-mini-profiler-2.3.3/lib/patches/db/pg.rb:110:in `async_exec'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/postgresql                                       /database_statements.rb:47:in `block (2 levels) in execute'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/dependencies/interlock.rb:48                                       :in `block in permit_concurrent_loads'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/concurrency/share_lock.rb:18                                       7:in `yield_shares'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/dependencies/interlock.rb:47                                       :in `permit_concurrent_loads'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/postgresql                                       /database_statements.rb:46:in `block in execute'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract_a                                       dapter.rb:696:in `block (2 levels) in log'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/concurrency/load_interlock_a                                       ware_monitor.rb:26:in `block (2 levels) in synchronize'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/concurrency/load_interlock_a                                       ware_monitor.rb:25:in `handle_interrupt'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/concurrency/load_interlock_a                                       ware_monitor.rb:25:in `block in synchronize'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/concurrency/load_interlock_a                                       ware_monitor.rb:21:in `handle_interrupt'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/concurrency/load_interlock_a                                       ware_monitor.rb:21:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract_a                                       dapter.rb:695:in `block in log'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activesupport-6.1.4.1/lib/active_support/notifications/instrumenter.r                                       b:24:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/abstract_a                                       dapter.rb:687:in `log'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/connection_adapters/postgresql                                       /database_statements.rb:45:in `execute'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/migration.rb:929:in `block in                                        method_missing'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/migration.rb:897:in `block in                                        say_with_time'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/migration.rb:897:in `say_with_                                       time'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/migration.rb:918:in `method_mi                                       ssing'
/var/www/discourse/db/migrate/20211213060445_email_tokens_token_to_nullable.rb:16:in `up'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/migration.rb:870:in `public_se                                       nd'
/var/www/discourse/vendor/bundle/ruby/2.7.0/gems/activerecord-6.1.4.1/lib/active_record/migration.rb:870:in `exec_migr                                       ation'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:9:in `block in exec_migration'
/var/www/discourse/lib/freedom_patches/schema_migration_details.rb:8:in `exec_migration'
I think this is the same issue as this other topic, let’s keep all the discussion there:
