After update "officials components" no longer working
Hello
I just updated to the latest version of Discourse:2026.3.0-latest (9d43e1f314)
Several theme components and plugins are no longer working.
Since some is “official,” could there be an issue in the latest Discourse releases?
The non-functional components are:
  • Topic Card (official)
  • Icon Header Links (official)
  • User Card Directory (official)
  • category header
  • Featured Lists
  • progress Bar
And the plugin: Location works only partially.
Thank you for your help.
The forum in question: https://forums.ffjdr.org/
I see an error on the site in the browser console:
Uncaught (in promise) Error: Could not find module `discourse/lib/posts-with-placeholders` imported from `discourse/plugins/discourse-journal/discourse/initializers/journal-post`
I believe this comes from Journal Plugin, which is currently listed as broken — if you remove that plugin, I believe the components should start working again.
You can confirm it’s a plugin issue by using safe mode to disable plugins https://forums.ffjdr.org/?safe_mode=no_plugins — when viewing the site this way the components appear to work.
Thank you for the quick response :pray:
This completely resolved the issue :smiling_face_with_sunglasses:
