AI:embeddings:backfill - OpenAIのExcessive Tokensによる400エラーへの対応
OpenAI の埋め込みを使用して、この Rake タスクを実行しようとしています。
エラーメッセージが表示されます
[:/var/www/discourse# rake ai:embeddings:backfill --trace
** Invoke ai:embeddings:backfill (first_time)
** Invoke environment (first_time)
** Execute environment
** Execute ai:embeddings:backfill
.rake aborted!
Net::HTTPBadResponse: Net::HTTPBadResponse (Net::HTTPBadResponse)
/var/www/discourse/plugins/discourse-ai/lib/inference/open_ai_embeddings.rb:27:in `perform!’
/var/www/discourse/plugins/discourse-ai/lib/embeddings/vector_representations/text_embedding_ada_002.rb:36:in `vector_from’
/var/www/discourse/plugins/discourse-ai/lib/embeddings/vector_representations/base.rb:144:in `generate_representation_from’
/var/www/discourse/plugins/discourse-ai/lib/tasks/modules/embeddings/database.rake:19:in `block (2 levels) in ’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8/lib/active_record/relation/batches.rb:71:in `each’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8/lib/active_record/relation/batches.rb:71:in `block in find_each’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8/lib/active_record/relation/batches.rb:138:in `block in find_in_batches’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8/lib/active_record/relation/batches.rb:245:in `block in in_batches’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8/lib/active_record/relation/batches.rb:229:in `loop’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8/lib/active_record/relation/batches.rb:229:in `in_batches’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8/lib/active_record/relation/batches.rb:137:in `find_in_batches’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/activerecord-7.0.8/lib/active_record/relation/batches.rb:70:in `find_each’
/var/www/discourse/plugins/discourse-ai/lib/tasks/modules/embeddings/database.rake:17:in `block in ’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/task.rb:281:in `block in execute’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/task.rb:281:in `each’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/task.rb:281:in `execute’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/task.rb:219:in `block in invoke_with_call_chain’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/task.rb:199:in `synchronize’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/task.rb:199:in `invoke_with_call_chain’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/task.rb:188:in `invoke’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:182:in `invoke_task’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:138:in `block (2 levels) in top_level’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:138:in `each’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:138:in `block in top_level’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:147:in `run_with_threads’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:132:in `top_level’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:83:in `block in run’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:208:in `standard_exception_handling’
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rake-13.1.0/lib/rake/application.rb:80:in `run’
bin/rake:13:in `<top (required)>’
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.5.3/lib/bundler/cli/exec.rb:58:in `load’
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.5.3/lib/bundler/cli/exec.rb:58:in `kernel_load’
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.5.3/lib/bundler/cli/exec.rb:23:in `run’
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.5.3/lib/bundler/cli.rb:451:in `exec’
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.5.3/lib/bundler/vendor/thor/lib/thor/command.rb:28:in `run’
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.5.3/lib/bundler/vendor/thor/lib/thor/invocation.rb:127:in `invoke_command’
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.5.3/lib/bundler/vendor/thor/lib/thor.rb:527:in `dispatch’
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.5.3/lib/bundler/cli.rb:34:in `dispatch’
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.5.3/lib/bundler/vendor/thor/lib/thor/base.rb:584:in `start’
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.5.3/lib/bundler/cli.rb:28:in `start’
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.5.3/exe/bundle:28:in `block in <top (required)>’
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.5.3/lib/bundler/friendly_errors.rb:117:in `with_friendly_errors’
/usr/local/lib/ruby/gems/3.2.0/gems/bundler-2.5.3/exe/bundle:20:in `<top (required)>’
/usr/local/bin/bundle:25:in `load’
/usr/local/bin/bundle:25:in `’
Tasks: TOP => ai:embeddings:backfill
読む必要はありません。問題は解決しました。
HTTPBadResponse が次の行からスローされています。
/logs ページには次のように表示されます。
OpenAI Embeddings failed with status: 400 body: {
  "error": {
    "message": "This model's maximum context length is 8192 tokens, however you requested 8506 tokens (8506 in your prompt; 0 for the completion). Please reduce your prompt; or completion length.",
    "type": "invalid_request_error",
    "param": null,
    "code": null
基本的に、単語が多すぎるようです。「プロンプト」と「完了」の違いがこの文脈ではわかりません。いずれにしても、これはバックフィルを妨げています。
サイト設定で最大投稿制限を変更しましたが、これは非常に長い投稿が原因である可能性がありますか?この場合でも、投稿コンテンツは切り捨てられるか、またはその投稿はスキップされると予想されますか?いずれにしても、バックフィルプロセス全体がブロックされています。
「いいね!」 1
レポートありがとうございます。月曜日に確認します。
「いいね!」 2
OpenAIトークナイザーを使用して送信前にコンテンツを切り捨てているため、これは予期しないエラーです。
問題のテキストを共有していただけますか?
スタックトレースと400エラーしか見えません。リクエストが何であったかを確認できる場所はありますか?そうでなければ、問題を引き起こしているテキストが何であるか分かりません。
rake タスクを実行しているので、ファイルを編集して、18 行目と 19 行目の間に puts t.id を追加してトピック ID を出力できますか。
ご指導ありがとうございます。とんでもないエッジケースを見つけたと思います。
問題はザルゴテキストでした。
つまり、この類のものです。
この「ハローワールド」は、すべてのジャンクが付いた状態で607文字になります。
そのうちのいくつかが投稿されていたので、削除しました。バックフィルは続行できました。おそらく優先度の高い問題ではありませんが、私のフォーラムにこのような投稿をしているのは私だけではないはずです。
それは興味深いですね。OpenAIのトークナイザーに問題が発生し、カウントが間違っているのだと思います。
「いいね!」 2
これは公式のトークナイザーのバグである可能性があります!
私たちのカウントは完全に一致しています!
また…トークンカウントを見ると、ザルゴテキストはほとんど価値がないのにトークン数を膨張させるため、AIにとって非常に強力な攻撃であることがわかります。
@piffy、https://platform.openai.com/tokenizer に正確なテキストを貼り付けて、トークンカウントがAPIの言うことと一致するかどうかを確認していただけますか?OpenAIの再現手順があるかもしれません。
「いいね!」 2
上記は、「編集」をクリックしたときに表示される生の投稿コンテンツです。
より詳しい状況を説明すると、これはトピックが埋め込まれなかった際の不具合であり、トピック全体がどのように埋め込まれるかの実装詳細は不明です。しかし、この投稿を削除したところ、問題が解決したことはお伝えできます。:laughing:
このスレッドに投稿すると問題が再発する可能性があるため、元のメッセージはチャットでお送りできます。
修正済み
「いいね!」 1
