AI helper נעלם ב-composer
סיכום מבוסס בינה מלאכותית
Users reported that the AI helper disappeared from the composer after recent Discourse updates, particularly on mobile devices like iPad and iPhone using DiscourseHub or Safari Mobile. Jagster noted it worked on Safari but not DiscourseHub, and later discovered the AI pop-up was hidden behind the composer due to a z-index issue Jagster. Don confirmed the issue affected Android too and linked it to a specific commit, suggesting a mobile view z-index bug. keegan acknowledged the report, credited Don for pinpointing the cause, and confirmed the issue is now fixed via PR #749. The fix resolves visibility on mobile, though broader mobile UI issues (like composer height or navigation) remain noted. Screenshots illustrate the hidden pop-up and desktop workaround Don.
I upgraded recently because of that rebuilding-issue by Dsicourse AI (or what ever it was). After that AI helper disappeared from composer. It show tools for title, category and tags, but that pop-up took a sickday.
Because it happends here and on my forum, and because my settings for AI helper are valid, I would guess something has broken.
edit
This is strange. When I’m using iPad on iPadOS 16.7.8 helper of composer
  • doesn’t show up with DiscourseHub
  • does work with Safari
But iPhone with totally fresh 17.6.1 refuses show AI helper in composer totally.
What other devices do or not do… I don’t know. All I know couple days ago AI helper worked without problems. And after that came two fixes to Discourse: that rebuilding error and automatic caption.
4 לייקים
It still works for me:
3 לייקים
So do I if I use Safari instead of DiscourseHub. So, I need to start new topic, because the issue seems to be DiscourseHub.
Well, I have to do few more tests. I’ll fix this topic a bit later.
2 לייקים
I figured it out. Kind of. That pop-up is there but it is hidden behind composer.
If you try you can find it.
That specific one may be fixed relatively easy, perhaps, but this may be part of wide problem how Discourse works on i-devices. And there is several ones, like (again) three visible rows in composer, difficulties browse users, categories etc.
2 לייקים
@keegan confirmed, this is not working in Safari Mobile (both hub and Safari)
3 לייקים
It seems this affects android too. I think this commit is related.
This should be a z-index issue on mobile view. :thinking:
If I change it to desktop view it will appears.
4 לייקים
Thanks for submitting this report @Jagster
Thanks @Don for narrowing down the issue so I can push out a quicker fix.
This should now be resolved :tada:
https://github.com/discourse/discourse-ai/pull/749
5 לייקים
This topic was automatically closed after 15 hours. New replies are no longer allowed.
