Don
August 13, 2024, 4:09am
1
Partly continuing this topic: AI helper has disappeared in composer
Hello
I think this is only cause issue on Android because the context menu is opening on the selected text top. Now the AI helper is opening on the top position too which makes it unusable most of time.
On the top line it aligns well but the distance is missing to the bubble.
Otherwise it opens on top position
Thanks
sam
(Sam Saffron)
August 13, 2024, 4:39am
@awesomerobot / @keegan I do wonder if we should use a different paradigm for mobile.
Maybe trying to fight with mobile context menus is too hard?
I guess we can play wack-a-mole and render it 20px off, but I am not sure this is winnable long term.
For example we could possibly use this area quite safely on mobile?
Jagster
(Jakke Flemming)
August 13, 2024, 5:26am
3
Yes please. Because normally I need almost every time tapping selected text twice to get context menu disappearing, because helper is totally or partly under it. But iPhone 15 with newest iOS doesn’t work like that anymore. If I make context menu diappeared helper will vanish too.
Sure I can roll a phone here, there and everywhere and sometimes I got helper visible but sometimes it jumped somewhere else totally randomly.
Yeah. Not android things anymore, but I don’t see any point to discuss of same thing in several topics.
But the bubble can be moved, correct?
sam
(Sam Saffron)
August 13, 2024, 7:02am
5
It can but different OSes render the native hover menu in different places.
We have no control over what Android / Apple core devs do and can not inject into the native hover menu.
Don
August 13, 2024, 7:14am
6
It can but if I want to select only that word it’s still a problem.
It’s the same situation like with this one: Quoting popup positioning on mobile
keegan
(Keegan George)
August 21, 2024, 6:28pm
18
This should be now resolved with:
committed 06:01PM - 21 Aug 24 UTC
Co-authored-by: Keegan George <kgeorge13@gmail.com>
Thanks @chapoi
Don
August 21, 2024, 6:38pm
21
Thanks it looks great. One thing I noticed, it’s not calculate with keyboard.
keegan
(Keegan George)
August 21, 2024, 6:45pm
22
Hmm, its working for me on iOS. Perhaps, its an Android specific issue.
Will do some testing on an Android device and see if I can resolve the issue.
Jagster
(Jakke Flemming)
August 21, 2024, 6:48pm
24
Let’s put iPad on that list too… Nope, still somewhere.
keegan
(Keegan George)
August 21, 2024, 7:05pm
25
@Don Hmm, its working on my Android device Can you share more details on what device you’re using?
Don
August 21, 2024, 7:14pm
26
Huawei P20 Pro
Android 10; CLT-L29 Build/HUAWEICLT-L29
Chrome 127.0.6533.103
chapoi
August 21, 2024, 7:48pm
27
So, very odd, it didn’t work for me either with the virtual keyboard, but now it suddenly does. Can you please refresh and try again to confirm it’s still not showing up? (for the Ipad, Android is different issue)
Thanks!
Don
August 21, 2024, 8:13pm
28
Yeah, on Android works for me if I adds the env(keyboard-inset-height) to the top calculation.
top: calc(var(--mobile-virtual-screen-height) - var(--composer-helper-menu-height) - env(keyboard-inset-height));
Falco
(Falco)
August 21, 2024, 8:14pm
29
Also doesn’t work for me on Android.
On Android we use the proper keyboard visibility API, so it’s an easy fix following the @Don suggestion, instead of the pain of iOS.
Falco
(Falco)
August 22, 2024, 2:12pm
33
This is now working on Android too.
Jagster
(Jakke Flemming)
August 22, 2024, 2:25pm
34
Too? You ment to say ”androids only”?
chapoi
August 22, 2024, 2:30pm
35
No, it’s working on our iphones too. Are you referring to your ipad still not working then?
Jagster
(Jakke Flemming)
August 22, 2024, 2:33pm
36
My iPhone didn’t work here, but so doesn’t iPad. So either it is still broken or I don’t have anymore rights to use AI helper on composer.
But I’ll rebuild my forum and lets see if situation is different.
Can it be issue of the Hub No, it is not.
chapoi
August 22, 2024, 2:35pm
37
This is on my Iphone on Meta:
selecting large enough text (min 3 chars I think)
you dont get the popup in the right bottom corner?
