So I updated all the google vertex LLM to Interaction Endpoints and recently I started noticing this error in the logs as AI was no longer responding to posts automatically. What’s going on here? It was working initially but stopped working a few weeks ago.
Using Flash 3.7 and 3.8 for the various agents. AI Bot , Forum Helper, Inferred Concepts using 3.8, others using 3.7 with thinking this config:
Message
Error responding to: /t/metadata-lookups-failing-for-movie-stargate-the-ark-of-truth/5969/2 in LlmAgentTriage.handle : DiscourseAi::Completions::Endpoints::Base::CompletionFailed : {"error":{"message":"Model turns with thought summaries must start with a thought block in thinking models.","code":"invalid_request"}}
Backtrace
/var/www/discourse/plugins/discourse-ai/lib/completions/endpoints/base.rb:499:in 'block (3 levels) in DiscourseAi::Completions::Endpoints::Base#perform_completion_request_with_retries'
net-http-0.9.1/lib/net/http.rb:2461:in 'block in Net::HTTP#transport_request'
net-http-0.9.1/lib/net/http/response.rb:321:in 'Net::HTTPResponse#reading_body'
net-http-0.9.1/lib/net/http.rb:2458:in 'Net::HTTP#transport_request'
net-http-0.9.1/lib/net/http.rb:2410:in 'Net::HTTP#request'
rack-mini-profiler-5.0.0/lib/patches/net_patches.rb:19:in 'block in Net::HTTP#request_with_mini_profiler'
rack-mini-profiler-5.0.0/lib/mini_profiler/profiling_methods.rb:51:in 'Rack::MiniProfiler::ProfilingMethods#step'
rack-mini-profiler-5.0.0/lib/patches/net_patches.rb:18:in 'Net::HTTP#request_with_mini_profiler'
/var/www/discourse/plugins/discourse-ai/lib/completions/endpoints/base.rb:487:in 'block (2 levels) in DiscourseAi::Completions::Endpoints::Base#perform_completion_request_with_retries'
net-http-0.9.1/lib/net/http.rb:1630:in 'Net::HTTP#start'
net-http-0.9.1/lib/net/http.rb:1064:in 'Net::HTTP.start'
/var/www/discourse/plugins/discourse-ai/lib/completions/endpoints/base.rb:468:in 'block in DiscourseAi::Completions::Endpoints::Base#perform_completion_request_with_retries'
<internal:kernel>:168:in 'Kernel#loop'
/var/www/discourse/plugins/discourse-ai/lib/completions/endpoints/base.rb:444:in 'DiscourseAi::Completions::Endpoints::Base#perform_completion_request_with_retries'
/var/www/discourse/plugins/discourse-ai/lib/completions/endpoints/base.rb:196:in 'DiscourseAi::Completions::Endpoints::Base#perform_completion!'
/var/www/discourse/plugins/discourse-ai/lib/completions/llm.rb:258:in 'DiscourseAi::Completions::Llm#generate'
/var/www/discourse/plugins/discourse-ai/lib/agents/bot.rb:292:in 'DiscourseAi::Agents::Bot#reply'
/var/www/discourse/plugins/discourse-ai/lib/ai_bot/playground.rb:669:in 'DiscourseAi::AiBot::Playground#reply_to'
/var/www/discourse/plugins/discourse-ai/lib/ai_bot/playground.rb:224:in 'DiscourseAi::AiBot::Playground.reply_to_post'
/var/www/discourse/plugins/discourse-ai/lib/automation/llm_agent_triage.rb:13:in 'DiscourseAi::Automation::LlmAgentTriage.handle'
/var/www/discourse/plugins/discourse-ai/discourse_automation/llm_agent_triage.rb:44:in 'block (2 levels) in <main>'
/var/www/discourse/plugins/automation/app/models/discourse_automation/automation.rb:163:in 'block in DiscourseAutomation::Automation#trigger!'
/var/www/discourse/plugins/automation/app/models/discourse_automation/stat.rb:12:in 'DiscourseAutomation::Stat.log'
/var/www/discourse/plugins/automation/app/models/discourse_automation/automation.rb:161:in 'DiscourseAutomation::Automation#trigger!'
/var/www/discourse/plugins/automation/app/jobs/regular/discourse_automation/trigger.rb:30:in 'Jobs::DiscourseAutomation::Trigger#execute'
/var/www/discourse/app/jobs/base.rb:313:in 'block (2 levels) in Jobs::Base#perform'
rails_multisite-9.0.0/lib/rails_multisite/connection_management/null_instance.rb:54:in 'RailsMultisite::ConnectionManagement::NullInstance#with_connection'
rails_multisite-9.0.0/lib/rails_multisite/connection_management.rb:23:in 'RailsMultisite::ConnectionManagement.with_connection'
/var/www/discourse/app/jobs/base.rb:300:in 'block in Jobs::Base#perform'
/var/www/discourse/app/jobs/base.rb:297:in 'Array#each'
/var/www/discourse/app/jobs/base.rb:297:in 'Jobs::Base#perform'
sidekiq-7.3.10/lib/sidekiq/processor.rb:220:in 'Sidekiq::Processor#execute_job'
sidekiq-7.3.10/lib/sidekiq/processor.rb:185:in 'block (4 levels) in Sidekiq::Processor#process'
sidekiq-7.3.10/lib/sidekiq/middleware/chain.rb:180:in 'Sidekiq::Middleware::Chain#traverse'
sidekiq-7.3.10/lib/sidekiq/middleware/chain.rb:183:in 'block in Sidekiq::Middleware::Chain#traverse'
/var/www/discourse/lib/sidekiq/suppress_user_email_errors.rb:6:in 'Sidekiq::SuppressUserEmailErrors#call'
sidekiq-7.3.10/lib/sidekiq/middleware/chain.rb:182:in 'Sidekiq::Middleware::Chain#traverse'
/var/www/discourse/lib/sidekiq/discourse_event.rb:6:in 'Sidekiq::DiscourseEvent#call'
/var/www/discourse/lib/sidekiq/pausable.rb:136:in 'Sidekiq::Pausable#call'
sidekiq-7.3.10/lib/sidekiq/job/interrupt_handler.rb:9:in 'Sidekiq::Job::InterruptHandler#call'
sidekiq-7.3.10/lib/sidekiq/metrics/tracking.rb:26:in 'Sidekiq::Metrics::ExecutionTracker#track'
sidekiq-7.3.10/lib/sidekiq/metrics/tracking.rb:134:in 'Sidekiq::Metrics::Middleware#call'
sidekiq-7.3.10/lib/sidekiq/middleware/chain.rb:173:in 'Sidekiq::Middleware::Chain#invoke'
sidekiq-7.3.10/lib/sidekiq/processor.rb:184:in 'block (3 levels) in Sidekiq::Processor#process'
sidekiq-7.3.10/lib/sidekiq/processor.rb:145:in 'block (6 levels) in Sidekiq::Processor#dispatch'
sidekiq-7.3.10/lib/sidekiq/job_retry.rb:118:in 'Sidekiq::JobRetry#local'
sidekiq-7.3.10/lib/sidekiq/processor.rb:144:in 'block (5 levels) in Sidekiq::Processor#dispatch'
sidekiq-7.3.10/lib/sidekiq/config.rb:39:in 'block in <class:Config>'
sidekiq-7.3.10/lib/sidekiq/processor.rb:139:in 'block (4 levels) in Sidekiq::Processor#dispatch'
sidekiq-7.3.10/lib/sidekiq/processor.rb:281:in 'Sidekiq::Processor#stats'
sidekiq-7.3.10/lib/sidekiq/processor.rb:134:in 'block (3 levels) in Sidekiq::Processor#dispatch'
sidekiq-7.3.10/lib/sidekiq/job_logger.rb:15:in 'Sidekiq::JobLogger#call'
sidekiq-7.3.10/lib/sidekiq/processor.rb:133:in 'block (2 levels) in Sidekiq::Processor#dispatch'
sidekiq-7.3.10/lib/sidekiq/job_retry.rb:85:in 'Sidekiq::JobRetry#global'
sidekiq-7.3.10/lib/sidekiq/processor.rb:132:in 'block in Sidekiq::Processor#dispatch'
sidekiq-7.3.10/lib/sidekiq/job_logger.rb:40:in 'Sidekiq::JobLogger#prepare'
sidekiq-7.3.10/lib/sidekiq/processor.rb:131:in 'Sidekiq::Processor#dispatch'
sidekiq-7.3.10/lib/sidekiq/processor.rb:183:in 'block (2 levels) in Sidekiq::Processor#process'
sidekiq-7.3.10/lib/sidekiq/processor.rb:182:in 'Thread.handle_interrupt'
sidekiq-7.3.10/lib/sidekiq/processor.rb:182:in 'block in Sidekiq::Processor#process'
sidekiq-7.3.10/lib/sidekiq/processor.rb:181:in 'Thread.handle_interrupt'
sidekiq-7.3.10/lib/sidekiq/processor.rb:181:in 'Sidekiq::Processor#process'
sidekiq-7.3.10/lib/sidekiq/processor.rb:86:in 'Sidekiq::Processor#process_one'
sidekiq-7.3.10/lib/sidekiq/processor.rb:76:in 'Sidekiq::Processor#run'
sidekiq-7.3.10/lib/sidekiq/component.rb:10:in 'Sidekiq::Component#watchdog'
sidekiq-7.3.10/lib/sidekiq/component.rb:19:in 'block in Sidekiq::Component#safe_thread'
