Allow Events only in some Topics
I understand the concept behind the “new” calendar and can see that it works really well for many communities.
Unfortunately, we have different permissions and it would be very time-consuming to set it up in such a way that we can map our functions.
We would very much like to allow the calendar in only a few categories, namely 5 categories with different permissions. If I had to map these five levels within each working group, it would be a lot of work and still wouldn’t prevent someone outside these categories from creating events.
Also it is not only who can join, also who can see events. So that´s why limiting special categories would be perfect.
As admins and mods, we can always make sure that all members adhere to the guidelines, but it would certainly be easiest if I could select calendar categories.
The best setting would probably be:
- Allow everywhere
- Allow only in categories [List of Cat]
- Prevent events in categories [List of Cat]
That would be wonderful.
Thanks for your time and best regards
Richarde
