האם ניתן עדיין לראות אירועים פרטיים על ידי מי שלא הוזמן לאירוע פרטי זה?
סיכום מבוסס בינה מלאכותית
A user, jordan-violet, reported an issue with private events being visible to non-invited users. JammyDodger clarified that the “Private” option only controls who can join the event, not its visibility. To restrict event visibility, it’s suggested to use a restricted category. jordan-violet noted that this would require multiple event categories for different user/group combinations, highlighting the need for a feature to control event visibility based on user or group criteria. As a temporary solution, JammyDodger suggested using events in private messages (PMs) or group PMs, which can be viewed only by participants.
I created an event, chose the option for the event to be Private, and selected the user groups that it should be private to. I then impersonated a user not in that group, but the event was still publicly visible.
Am I misunderstanding how private events work?
I think ‘Private’ refers to who can join, rather than the event’s visibility:
For an event that should be visible to only some people it would need to be in a restricted category. That way it would show on the event calendar only to people who had permission to view that category.
I supposed we could have multiple events categories, but I guess then we’d have to have a different event category for every combination of users/groups that we wanted to create private events for.
Would be a great feature to add to the platform or plugin, to allow visibility control of specific topics based on user or group criteria.
Events also work in PMs/group PMs as well if that could work for you in the short term? If you sent a PM to the users or group with an event in, it will show in the /upcoming-events only for the PM participants.
