Not sure if this is the best place to comment about this but I will.
Are there any future plan to prepend “Solved:” in front of the solved question’s title?
That way the Solved: will also appear within the Search Engine Result Pages making it more likely to be clicked thus improving the Forums CTR.
Regards
5 个赞
I’d second this request.
However I’d not prepend a String. There is such a feature for the normal topics overview, e.g. the latest view:
Is it planed to move the tick symbol to search results as well?
3 个赞
tophee
(Christoph)
2017 年3 月 3 日 19:21
3
How about prepending [solved] invisibly for search engines but keeping visual appearance as it is?
3 个赞
sam
(Sam Saffron)
2017 年3 月 4 日 23:36
4
Today this can be done with CSS :before as you have a distinct class for solved topics on topic-list-item
5 个赞
jonathon
(Jonathon)
2018 年3 月 28 日 11:18
5
I’ve just tried implementing this and the only way I could get it to take effect (with the ability to style it independently of the checkmark) was via:
.fa-check-square-o::after {
content: " [SOLVED]";
Inspector
topic-list-item doesn’t appear to have a class for “solved”, I can see e.g. “liked”, “pinned”, “visited”, …
This isn’t great to read as the font-family used is fontawesome, and while it can be overridden it’s an extra place to explicitly set a variable.
The other downside of this is that it doesn’t show in internal search.
If I try to set this as hidden for users but available for external search engines (if this would even work) with e.g.:
display: none;
then the rule is optimised out of the compiled CSS (whereas visibility: hidden leaves a nice gap).
notriddle
(Michael Howell)
2018 年3 月 28 日 14:12
6
Wait, what? The CSS isn’t used by search engines! To do that, you need to modify the noscript version of the page .
4 个赞
