在更新主题组件时出现“空字符串不是有效的JSON字符串”错误
更新主题组件时,会发生以下错误。
更新 Brand Header 主题组件失败
空字符串不是有效的 JSON 字符串。
/var/www/discourse/lib/theme_settings_manager/objects.rb:13:in `parse'
/var/www/discourse/lib/theme_settings_manager/objects.rb:13:in `value='
/var/www/discourse/app/models/theme.rb:760:in `update_setting'
/var/www/discourse/app/models/theme.rb:881:in `block (2 levels) in migrate_settings'
/var/www/discourse/app/models/theme.rb:880:in `each'
/var/www/discourse/app/models/theme.rb:880:in `block in migrate_settings'
/var/www/discourse/app/models/theme.rb:919:in `migrate_settings'
/var/www/discourse/app/models/remote_theme.rb:377:in `block in update_from_remote'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/connection_adapters/abstract/transaction.rb:535:in `block in within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activesupport-7.1.3.4/lib/active_support/concurrency/null_lock.rb:9:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/connection_adapters/abstract/transaction.rb:532:in `within_new_transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/connection_adapters/abstract/database_statements.rb:344:in `transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/transactions.rb:212:in `transaction'
/var/www/discourse/vendor/bundle/ruby/3.3.0/gems/activerecord-7.1.3.4/lib/active_record/transactions.rb:301:in `transaction'
/var/www/discourse/app/models/remote_theme.rb:383:in `update_from_remote'
这与 GitHub - discourse/discourse-brand-header: Brand header theme component for Discourse 相关,该组件正在从 5b0c2da 更新到 f458dc9(因为 Discourse 正在从 3.2.4 更新到 3.3.0)。
发生这种情况的原因是“links”字段为空,并且更新逻辑似乎无法处理这种情况 @tgxworld
解决方法:
  • 在“links”字段中输入 foo,https://example.com,bar
  • 更新主题组件
  • 打开链接编辑器并删除条目
但是,这个解决方法很难自动化…… :sob:
4 个赞
我今天会看看这个。
3 个赞
此问题已在以下位置修复:
很可能在未来 24 小时内合并并发布。
4 个赞
此主题已在 3 天后自动关闭。不再允许回复。
