Anonymous posting
Don’t see how you can post anonymously on the boards. I set up a test/regular member account and do not see anonymous mode or anonymous posting options.
Can Admins/Mods see which user posted anonymously too?
Also can you set up anonymous posting/mode so only users with a certain amount of trust can use it?
Look under your user menu to enter anonymous mode, it is the spy glyph
I don’t see that anywhere.
OK, if you don’t see that, then anonymous mode has not been enabled in your Admin, Site Settings.
Just checked and I did. :confused:
It looks like you set the “min trust level to post anonymously” to 5… there is no trust level 5.
I reset that setting to default, and now I see it.
@techapj can we add a validation to this site setting, so it is not set to an invalid value?
Done via:
