In a UX-focused discussion titled âAny way to display Location below the name in posts?â, Chandra asks if itâs possible to show a userâs profile location (specifically town/city) beneath their username in posts to boost engagement. pfaffman suggests a plugin would be needed to modify the serializer, noting that a theme component alone would be inefficient. merefield recommends a national flags plugin for country-level display, but Chandra clarifies the need for finer granularity (city/town). pfaffman points to the flag plugin as a code reference for building a custom solution. renato mentions the Locations plugin, which can display location under usernames â though it uses a custom field. Chandra notes it currently shows map links and plans to explore adapting it to display plain location names. renato adds that the plugin allows disabling geocoding to store location as a simple string, which may meet Chandraâs needs.
Hi, is there a way to display the location of a member (from the profile) below the user name in posts?
Location has a significant bearing on our site discussions and displaying the location improves engagement. I am aware it is in the user cards but am looking to have it in the posts.
Thank you.
Looks like youâd need a plugin to add the location to the serializer. The alternative with a theme component would take a bunch of API calls, so I think you donât want to do it that way.
If youâre self-hosted you could make or commission a plugin to add the information and then it would be easy enough to add the location to a theme component (or in the plugin).
IIRC the locations plugin has an option to show the location below the username on all posts, but I think it uses a whole different/custom field for that.
This plugin is really powerful and has a lot of settings, I think you can just set location geocoding to none and the address field will be stored as string, with no geocoded location.
