On discourse:
you’ve
rendered correctly
On wordpress:
youâve
Not sure why ?
On discourse:
you’ve
rendered correctly
On wordpress:
youâve
Not sure why ?
Is this happening with comments that are embedded on WordPress with javascript, or with comments that are added through the WP Discourse plugin?
With the WP Discourse plugin. Everything is on the latest latest versions BTW
Do you know if this just started happening recently?
I can’t reproduce this, but the problem has to do with character encoding. I’ll keep looking at it. I’m wondering if this has anything to do with the font that’s used on your forum.
I am not sure if it’s a recent thing. Will have a look at font though.
Sites are discourse.adamprocter.co.uk and http://fragmentum.adamprocter.co.uk/episode-12-moodle-and-delightful/
Hopefully the latest version of the WP Discourse plugin will solve the character encoding issue for you. It’s in the WordPress plugin repository now.
Worked thank you ! Amazing
