In a support thread titled ‘Are there updated directions for moving posts?’, C_S seeks help moving posts between topics, noting that the 2019 documentation doesn’t match the current interface. After selecting posts via the wrench icon, no action box appears. JammyDodger and Lilly provide step-by-step guidance with screenshots, including selecting posts and using the ‘move to’ option. C_S confirms the box doesn’t appear, even after following instructions. Lilly shares updated visuals from the moderator guide. C_S reports no change. JammyDodger suggests testing in Safe Mode, which C_S confirms works — though only the ‘move post’ option is available. JammyDodger explains that Safe Mode disables custom themes/components, implying one may be hiding the UI element. C_S plans to consult the site owner, as the site is still under development, and will use Safe Mode temporarily for moderation until the issue is resolved. The thread highlights a UI conflict likely caused by custom code interfering with moderator tools.
Trying to find out how to move posts from one topic to another. The page on this site with that information is from 2019 and looks nothing like the page I’m working on. There is a testing topic set up. One person replied. I am trying to move that reply to another topic to ensure we know what to do if something needs to be moved.
At the bottom right of the screen there is a wrench. I click that and choose Select Posts. Once I click Select on the post I want to move, it says Selected and I have no idea what to do next.
There are four wrenches on the page, one under each of the two posts there, one on the bottom right on the page and one underneath the posts in the topic. None of the wrenches has an option to Move a post. Are there updated instructions somewhere so moderators can learn how to use these needed mod tools?
Thanks. I read the guide but your pictures do not match at all what’s happening. I click Select on a post, it is blue and says Selected but there is no box popping up anywhere on the page telling me I have selected posts or anything. I’m an admin on the server.
Thanks for this. That worked. The only option was to move the post. Do I have to view the site in Safe Mode at all times in order to be able to moderate?
If it shows up in safe mode but not normally this is generally an indicator that a custom theme or theme component has some stray code that is hiding it (and when safe mode disables it the box appears again).
Do you have any customisations that you think could be likely culprits?
I will have to ask the site owner. It’s an in-progress build so we are all learning at the same time. I really appreciate your help. I will use Safe Mode if I have to move something until we figure out what may be causing this. Cheers!
