ArgumentError: directory for pid=/.../unicorn.pid not writable
Looks like the conclusion here is that we need to update the minimum required Docker version check in
Is there a place other than this forum where this should be reported as a bug?
It’s not really a bug. It’s simply not enforcing a minimum version for docker. Enforcing minimum versions is fraught because enforcing a current version too soon is also something that is annoying.
The person who is best qualified to update the code is aware of the issue. It’s likely just not a high priority since if you keep your software up to date, you’d not have had an issue.
