Hi there,
I am stuck with the following. When executing the commande ./discourse-setup, I have the following error
Im not sure I understand the message, my website is live and running https://cp2077.eu/ with SSL.
Here is my app.yml
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
- "templates/sshd.template.yml"
## - "templates/web.ssl.template.yml"
## - "templates/web.letsencrypt.ssl.template.yml"
- "templates/web.socketed.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
#expose:
# - "2045:80" # http
# - "1443:443" # https
params:
db_shared_buffers: "1024MB"
#db_work_mem: "40MB"
#version: tests-passed
env:
LANG: en_US.UTF-8
UNICORN_WORKERS: 4
## Required. Discourse will not work with a bare IP number.
DISCOURSE_HOSTNAME: cp2077.eu
## Uncomment if you want the container to be started with the same
## hostname (-h option) as specified above (default "$hostname-$config")
#DOCKER_USE_HOSTNAME: true
DISCOURSE_DEVELOPER_EMAILS: 'myemail@yandex.com'
## TODO: The SMTP mail server used to validate new accounts and send notifications
# SMTP ADDRESS, username, and password are required
# WARNING the char '#' in SMTP password can cause problems!
DISCOURSE_SMTP_ADDRESS: smtp.mailgun.org
DISCOURSE_SMTP_PORT: 587
DISCOURSE_SMTP_USER_NAME: ******
DISCOURSE_SMTP_PASSWORD: ******
DISCOURSE_SMTP_ENABLE_START_TLS: true # (optional, default true)
## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
LETSENCRYPT_ACCOUNT_EMAIL: myemail@yandex.com
## The http or https CDN address for this Discourse instance (configured to pull)
## see https://meta.discourse.org/t/14857 for details
volumes:
- volume:
guest: /shared
- volume:
guest: /var/log
## Plugins go here
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
run:
## - exec: rails r "SiteSetting.notification_email='beatlicious@yandex.com'"
When I do the command ./launcher rebuild app, I have the following error:
fatal: not a git repository (or any of the parent directories): .git
Stopping old container
+ /usr/bin/docker stop -t 60 app
app
cd /pups && git pull && /pups/bin/pups --stdin
Already up to date.
I, [2020-07-11T01:41:07.468750 #1] INFO -- : Loading --stdin
I, [2020-07-11T01:41:07.482322 #1] INFO -- : > locale-gen $LANG && update-locale
I, [2020-07-11T01:41:07.556578 #1] INFO -- : Generating locales (this might take a while)...
Generation complete.
I, [2020-07-11T01:41:07.557419 #1] INFO -- : > mkdir -p /shared/postgres_run
I, [2020-07-11T01:41:07.562170 #1] INFO -- :
I, [2020-07-11T01:41:07.562833 #1] INFO -- : > chown postgres:postgres /shared/postgres_run
I, [2020-07-11T01:41:07.568411 #1] INFO -- :
I, [2020-07-11T01:41:07.569223 #1] INFO -- : > chmod 775 /shared/postgres_run
I, [2020-07-11T01:41:07.576449 #1] INFO -- :
I, [2020-07-11T01:41:07.577398 #1] INFO -- : > rm -fr /var/run/postgresql
I, [2020-07-11T01:41:07.582904 #1] INFO -- :
I, [2020-07-11T01:41:07.583623 #1] INFO -- : > ln -s /shared/postgres_run /var/run/postgresql
I, [2020-07-11T01:41:07.592257 #1] INFO -- :
I, [2020-07-11T01:41:07.593134 #1] INFO -- : > socat /dev/null UNIX-CONNECT:/shared/postgres_run/.s.PGSQL.5432 || exit 0 && echo postgres already running stop container ; exit 1
2020/07/11 01:41:07 socat[27] E connect(6, AF=1 "/shared/postgres_run/.s.PGSQL.5432", 36): No such file or directory
I, [2020-07-11T01:41:07.602436 #1] INFO -- :
I, [2020-07-11T01:41:07.602977 #1] INFO -- : > rm -fr /shared/postgres_run/.s*
I, [2020-07-11T01:41:07.608907 #1] INFO -- :
I, [2020-07-11T01:41:07.609638 #1] INFO -- : > rm -fr /shared/postgres_run/*.pid
I, [2020-07-11T01:41:07.619803 #1] INFO -- :
I, [2020-07-11T01:41:07.622598 #1] INFO -- : > mkdir -p /shared/postgres_run/10-main.pg_stat_tmp
I, [2020-07-11T01:41:07.629638 #1] INFO -- :
I, [2020-07-11T01:41:07.630522 #1] INFO -- : > chown postgres:postgres /shared/postgres_run/10-main.pg_stat_tmp
I, [2020-07-11T01:41:07.639523 #1] INFO -- :
I, [2020-07-11T01:41:07.651076 #1] INFO -- : File > /etc/service/postgres/run chmod: +x chown:
I, [2020-07-11T01:41:07.660620 #1] INFO -- : File > /etc/service/postgres/log/run chmod: +x chown:
I, [2020-07-11T01:41:07.668238 #1] INFO -- : File > /etc/runit/3.d/99-postgres chmod: +x chown:
I, [2020-07-11T01:41:07.679949 #1] INFO -- : File > /root/upgrade_postgres chmod: +x chown:
I, [2020-07-11T01:41:07.680746 #1] INFO -- : > chown -R root /var/lib/postgresql/10/main
chown: cannot access '/var/lib/postgresql/10/main': No such file or directory
I, [2020-07-11T01:41:07.685326 #1] INFO -- :
FAILED
Pups::ExecError: chown -R root /var/lib/postgresql/10/main failed with return #<Process::Status: pid 42 exit 1>
exec failed with the params {"cmd"=>["chown -R root /var/lib/postgresql/10/main", "[ ! -e /shared/postgres_data ] && install -d -m 0755 -o postgres -g postgres /shared/postgres_data && sudo -E -u postgres /usr/lib/postgresql/10/bin/initdb -D /shared/postgres_data || exit 0", "chown -R postgres:postgres /shared/postgres_data", "chown -R postgres:postgres /var/run/postgresql"]}
d639e83f5451b5039efb2333f3eca1166d34ff6dc582ee29a0734a4274080fa2
atlas@sknet:~/www/cp2077$
Can someone advise me how can I install and setup discourse? I followed the guide and stuck here. Thank you
