jack2
1
I get this error when installing a plugin in a docker instance:
Compressing: plugin-third-party-ea46d31326df4fb4ed1d79ef5ecad5179b0512d15492b09e348b67b027cced32.js
uglifyjs '/var/www/discourse/public/assets/_plugin-third-party-ea46d31326df4fb4ed1d79ef5ecad5179b0512d15492b09e348b67b027cced32.js' -p relative -c -m -o '/var/www/discourse/public/assets/plugin-third-party-ea46d31326df4fb4ed1d79ef5ecad5179b0512d15492b09e348b67b027cced32.js' --source-map-root '/assets' --source-map '/var/www/discourse/public/assets/plugin-third-party-ea46d31326df4fb4ed1d79ef5ecad5179b0512d15492b09e348b67b027cced32.js.map' --source-map-url '/assets/plugin-third-party-ea46d31326df4fb4ed1d79ef5ecad5179b0512d15492b09e348b67b027cced32.js.map'
Parse error at _plugin-third-party-ea46d31326df4fb4ed1d79ef5ecad5179b0512d15492b09e348b67b027cced32.js:637,7
async function onEvent(container, event) {
SyntaxError: Unexpected token: keyword (function)
at JS_Parse_Error.get (eval at <anonymous> (/usr/lib/node_modules/uglify-js/tools/node.js:27:1), <anonymous>:86:23)
at /usr/lib/node_modules/uglify-js/bin/uglifyjs:384:40
at time_it (/usr/lib/node_modules/uglify-js/bin/uglifyjs:620:15)
at /usr/lib/node_modules/uglify-js/bin/uglifyjs:345:9
at FSReqWrap.readFileAfterClose [as oncomplete] (fs.js:511:3)
Removing async/await fixes the issue. It looks like some es6 code is sent to uglifyjs before conversion to es5.
The error doesn’t always occur. A few days ago, I retried installing several times and it finally succeeded. But now I’m stuck again.
Falco
(Falco)
Did you name your plugin file name.js.es6 ?
jack2
3
Nope, none of my plugin files are named name.js.es6.
cpradio
(cpradio)
4
Hence the problem, you need to name them with that extension.
jack2
5
My plugin has just installed correctly, at the 3rd attempt.
cpradio
(cpradio)
6
If you want it to compile properly, make sure they have a .js.es6 extension, then it will work everytime.
sam
(Sam Saffron)
7
I am not even sure if we enabled async await in babel @eviltrout ? I certainly have never used it in the Discourse code base.
jack2
8
@Falco, if your question was about the extension of my files, then yes, I’m using .js.es6 everywhere.
eviltrout
(Robin Ward)
9
We are not transpiling that. It probably works in the browser if you’re using an evergreen one, but we don’t support it yet.
We could benefit from it, I just haven’t had the time to enable it, make sure the perf is good, and start converting code.
syl
10
Any news on this? Having it would be great.
sam
(Sam Saffron)
11
We did start using this in tests, have not decided on our strategy yet for using it in production or not.
syl
12
Have you made some progress on this?
sam
(Sam Saffron)
13
@eviltrout has started a long spike at moving us towards using ember CLI. Part of the work should sort this out as a side effect.
I would expect we have this solved some time in the next 8 months.
I have this issue too
https://github.com/spirobel/projects/issues/1
I use name.js.es6 everywhere.
Does this mean I need to remove async/await?
j.jaffeux
(Joffrey Jaffeux)
15
Yes we don’t support async/await yet as explained.
