月次リーダーボードクエリの作成を試みるも頭が爆発しそう
先月の当社の重要指標に基づくリーダーボードのクエリ構築を試みています:
  • 受け取った「いいね」
  • 解決されたトピック
  • 獲得したバッジ
まずは User Participation クエリをベースにし、不要な部分を除去して、その後 badges gained(獲得したバッジ)の追加を始めました。バッジ獲得分のクエリ単体は以下のようになります:
-- [params]
-- string :interval = 1 month
-- string :trunc = month
    SELECT user_id, count(id)
    FROM user_badges
    WHERE granted_at > date_trunc(:trunc, CURRENT_TIMESTAMP - INTERVAL :interval)
         AND granted_at < date_trunc(:trunc, CURRENT_TIMESTAMP)
    GROUP BY user_id
    ORDER BY count DESC
これは問題なく動作しますが、これを修正済みの User Participation クエリに変換しようとした瞬間、頭が爆発してしまいました:
-- [params]
    with
    t as (
      select date_trunc(:trunc, CURRENT_TIMESTAMP - INTERVAL :interval) as start,
        date_trunc(:trunc, CURRENT_TIMESTAMP) as end
    pr as (
        select user_id,
            count(1) as visits,
            sum(posts_read) as posts_read
        from user_visits, t
        where posts_read > 0
        and visited_at > t.start
        and visited_at < t.end
        group by user_id
    likes as (
      select
          post_actions.user_id as given_by_user_id,
          posts.user_id as received_by_user_id
      from t, post_actions
      left join posts
      on post_actions.post_id = posts.id
      where post_actions.created_at > t.start
      and post_actions.created_at < t.end
      and post_action_type_id = 2
    lr as (
      select received_by_user_id as user_id,
          count(1) as likes_received
      from likes
      group by user_id
    e as (
      select email, user_id
      from user_emails u
      where u.primary = true
    b as (
        SELECT b.user_id, count(1) as badges
        FROM user_badges b, t, pr
        WHERE granted_at > t.start
            AND granted_at < t.end
            AND pr.user_id = b.user_id
        GROUP BY b.user_id
    select pr.user_id,
           username,
           name,
           email,
           visits,
           coalesce(likes_received,0) as likes_received,
           coalesce(badges,0) as badges_recv
    from pr
    left join lr using (user_id)
    left join e using (user_id)
    left join users on pr.user_id = users.id
    order by
      likes_received desc,
      visits desc
以下のエラーが発生しています(まだ「解決されたトピック」の追加すら始めていません):
    PG::UndefinedColumn: ERROR:  column "badges" does not exist
    LINE 65:        coalesce(badges,0) as badges_recv                            ^
これは私には理屈が通じません。badges は明確に定義されているはずなのに… 詰まってしまいました。badges received(受け取ったバッジ)と topics solved(解決されたトピック)を追加してこのクエリを完成させるお手伝いをいただけると助かります!
I think you just need to add a join in there:
left join b on b.user_id = users.id
Ahh hell yes! Thanks! Now I need to figure out adding the topics solved to this
ok so to come back to this as I have moved down the path a fair bit… trying to restrict to only a specific group, and then to all but a specific group (two separate queries).
-- User participation
-- [params]
with
t as (
pr as (
    select user_id,
        count(1) as visits,
    from user_visits, t
    group by user_id
likes as (
  select
  left join posts
lr as (
  from likes
  group by user_id
e as (
  from user_emails u
r as (
SELECT p.user_id, count(p.id) as replies
    FROM posts p, t, pr
    WHERE p.post_type = 1 AND
        p.post_number > 1 AND
            (p.created_at > t.start and
            p.created_at < t.end) and
            p.user_id IN
                (select u.id
                from users u
                where u.primary_group_id = 41) AND
        and p.user_id not in ('-1', '-2')
        AND pr.user_id = p.user_id
        AND p.topic_id not in ('4','24','26','32','33','34','35','36','37','38','39','40')
GROUP BY p.user_id),
b as (
    GROUP BY b.user_id
select pr.user_id,
       username,
       name,
       email,
       visits,
       coalesce(likes_received,0) as likes_recv,
       coalesce(replies,0) as replies_made,
       coalesce(badges,0) as badges_recv,
       ((coalesce(likes_received,0) * 2) + (coalesce(replies,0) * 1) + (coalesce(badges,0) * 3)) as total_points
from pr
left join r on r.user_id = users.id
order by
  total_points desc NULLS LAST
Not sure where I would put the bits for that?
pinging @simon to see if he has any thoughts here
I think you could create another WITH query to get the users who belong to a group, and then do an inner join to the in_group table in your final query. This should exclude any records that don’t have a user_id in the in_group table
-- returns user_ids for a named group
WITH in_group AS (
SELECT
gu.user_id
FROM group_users gu
JOIN
groups g
ON g.id = gu.group_id
WHERE g.name = :group_name
If you want another query that excludes the members of a group, you could do something like this
not_in_group AS (
SELECT
u.id
FROM users u
WHERE u.id NOT IN (SELECT * FROM in_group)
So I added the following based on group ID instead of name
in_group AS (
    SELECT gu.user_id
    FROM group_users gu
    JOIN groups g ON g.id = gu.group_id
    WHERE g.id = 41
and then added in the left join
left join in_group on in_group.user_id = users.id
and the same list appears - didn’t change anything.
Using a LEFT JOIN is the problem here. You need to use an INNER JOIN so that only records that match in both tables are returned. An INNER JOIN can be written as just JOIN.
This is a helpful article: A Visual Explanation of SQL Joins.
Doh… I hate joins… =)
Thanks mate!
So @simon I have another question around this… I am breaking things down for badges, giving different weight to which badge type… and getting a weird error when I try to add things together:
PG::SyntaxError: ERROR:  syntax error at or near "+"
LINE 97: ...sce(badges1,0) * 3)) + (coalesce(badges2,0) * 2)) + (coalesc...
I am using “+” elsewhere in that line and it’s fine, but as soon as I try to break it down it gives that error…
Here is the query (wall of text hidden by spoiler):
Query
-- [params]
-- string :trunc = Day
-- string :interval = 1 day
-- string :start = 2018-06-01 00:00:00.000000
-- string :end = 2018-06-30 23:59:59.999999
with
--t as (
--  select date_trunc(:trunc, CURRENT_TIMESTAMP - INTERVAL :interval) as start,
--    date_trunc(:trunc, CURRENT_TIMESTAMP) as end
pr as (
    select user_id,
        count(1) as visits,
    from user_visits
    and visited_at between :start and :end
    group by user_id
likes as (
  select
  from post_actions
  left join posts
  where post_actions.created_at between :start and :end
lr as (
  from likes
  group by user_id
e as (
  from user_emails u
r as (
    FROM posts p, pr
            (p.created_at between :start and :end)
b1 as (
    SELECT b1.user_id, count(1) as badges1
    FROM user_badges b1, pr
    WHERE granted_at between :start and :end
        AND pr.user_id = b1.user_id
        AND b1.badge_id in (select id from badges where badge_type_id = 1)
    GROUP BY b1.user_id
b2 as (
    SELECT b2.user_id, count(1) as badges2
    FROM user_badges b2, pr
        AND pr.user_id = b2.user_id
        AND b2.badge_id in (select id from badges where badge_type_id = 2)
    GROUP BY b2.user_id
b3 as (
    SELECT b3.user_id, count(1) as badges3
    FROM user_badges b3, pr
        AND pr.user_id = b3.user_id
        AND b3.badge_id in (select id from badges where badge_type_id = 3)
    GROUP BY b3.user_id
select pr.user_id,
       username,
       name,
       email,
       visits,
       coalesce(badges1,0) as badges1_recv,
       coalesce(badges2,0) as badges2_recv,
       coalesce(badges3,0) as badges3_recv,
       ((coalesce(likes_received,0) * 2) + (coalesce(replies,0) * 1) + (coalesce(badges1,0) * 3)) + (coalesce(badges2,0) * 2)) + (coalesce(badges3,0) * 1)) as total_points
from pr
left join b1 on b1.user_id = users.id
left join b2 on b2.user_id = users.id
left join b3 on b3.user_id = users.id
order by
It is not a weird error, the code has a Syntax Error. Maybe you can see the issue better this way?
) as total_points
DOH! I missed my parentheses… thanks!
No problem, many times it just takes a second pair of eyes to see something.
I’m a big fan of readability and don’t skimp on verbosity or newlines especially when things start to get gnarly looking. I rely heavily on indentation to keep track of nesting but many prefer to use an IDE or text editor that auto-magically adds closers as soon as a starter is added.
And as I am continually refining this, I am trying to restrict posts/topics from certain categories from being included in the results, specifically categories 43, and 47-50 as seen in the query below, but they’re still included:
query
-- [params]
with
t as (
pr as (
    select user_id,
        count(1) as visits,
    from user_visits, t
    group by user_id
likes as (
  select
  left join posts
lr as (
  from likes
  group by user_id
e as (
  from user_emails u
r as (
    FROM posts p, t, pr
        AND p.topic_id not in ('4','24','26','32','33','34','35','36','37','38','39','40','43','47','48','49','50')
b1 as (
    FROM user_badges b1, t, pr
    WHERE granted_at between t.start and t.end
    GROUP BY b1.user_id
b2 as (
    FROM user_badges b2, t, pr
    GROUP BY b2.user_id
b3 as (
    FROM user_badges b3, t, pr
    GROUP BY b3.user_id
in_group AS (
    SELECT gu.user_id
    FROM group_users gu
   WHERE g.id = 41
select pr.user_id,
       username,
       name,
       email,
       visits,
           (coalesce(badges1,0) * 3) +
           (coalesce(badges2,0) * 2) +
       ) as total_points
from pr
order by
@simon do you have any thoughts on the above?
I haven’t run the full query. The first thing I would do is check that all the WITH statements are returning the results you are looking for. You can check them in your final query by running something like SELECT * FROM r.
If the WITH statements are returning the correct results, but rows are being returned in your final query that you expect to be excluded, then the issue is with the joins in the query. If the final result should only include rows that are found in your r table, the problem will be the left join you are using for the r table. A left join will return the complete set of records from Table A, with the matching records (where available) in Table B. If there is no match, the right side will contain null. Try using an inner join instead (JOIN and INNER JOIN are the same thing.)
Here’s a good reference on joins: A Visual Explanation of SQL Joins.
Yeah so the WITH query looks to maybe be the problem, as it is pulling every user regardless of the category the topic is in. For instance I have one user that it’s returning 9 posts but they are in those protected topic IDs (43, 47, 48, 49, 59):
r as (
    FROM posts p, t, pr
Are you sure the query is counting posts in the excluded topics and it’s not that the query is counting posts that are hidden, deleted, or not the current public_version?
It is counting posts in the excluded categories because one of the users has only posted in those categories and yet still shows up.
