Here is a “Topic Participation” query, someone else is going to want to check it though.
Data Explorer: topic-participation.dcquery (v4).json (7.9 KB)
- EDIT #1 Updated to handle including rows for month when data doesn’t exist.
- EDIT #2 Updated to check for responses within X days (default 15)
- EDIT #3 Updated to:
- include posts information
- separated exclusions for “topics created by user from group” and “posts created by user from group”
- impersonate a particular users view of topics - use an admin user to see everything.
- optionally restrict results to that month (
-1) for responses or check for replies within X days.
- support output of response rate as percentage ready for Excel.
- WARNING: You might want to look further down this thread to see if anybody has sanity checked the query.
Parameters
impersonate
- Username to view of topics as - use an admin username like
system user to see everything.
exclude_groups_topics
- list of user groups (separated by a comma) to exclude topics from
- enter a single comma (
,) to not exclude any.
- if the group doesn’t exist, no exclusion will occur (check your spelling)
exclude_groups_replies
- list of user groups (separated by a comma) to exclude replies from
- if the group doesn’t exist, no exclusion will occur.
exclude_category_slugs
- list of category slugs (separated by a comma) to exclude topics from
reply_within_x_days
- Set to
-1 to restrict responses check to that month (default).
- Set to
0 to restrict responses to the same day topic was created.
- Set to
15 to count as response up to 15 day after initial topic creation even if 15 days is outside of that month.
pct_multiplier and pct_places
- Set
pct_multiplier to 1 and pct_places to 6 to get percent values ready for Excel.
- Set
pct_multiplier to 100 and pct_places to 1 to display as readable percentage values (default).
-- [params]
-- string :impersonate = system
-- string :exclude_groups_topics = staff
-- string :exclude_groups_replies = ,
-- string :exclude_category_slugs = staff,dev,simply-thank-you,was-it-you,wanted
-- int :reply_within_x_days = -1
-- int :pct_multiplier = 100
-- int :pct_places = 1
WITH
year_months AS (
SELECT
to_char(date(day),'YYYY-MM') as year_month
FROM
generate_series(
(date_trunc('month', CURRENT_DATE) - INTERVAL '1 year' ),
CURRENT_DATE,
interval '1 month'
) AS day
impersonated_usernames AS (
SELECT unnest(string_to_array( :impersonate, ',')) AS username
impersonated_users AS (
SELECT id
FROM users AS u
JOIN impersonated_usernames iun ON iun.username = u.username
WHERE iun.username = u.username
excluded_group_names_topics AS (
SELECT unnest(string_to_array( :exclude_groups_topics, ',')) AS name
excluded_group_names_replies AS (
SELECT unnest(string_to_array( :exclude_groups_replies, ',')) AS name
excluded_users_topics AS (
SELECT user_id AS id
FROM users AS u
JOIN group_users AS gu ON gu.user_id = u.id
JOIN groups AS g ON g.id = gu.group_id
JOIN excluded_group_names_topics eg ON eg.name = g.name
WHERE g.name = eg.name
excluded_users_replies AS (
FROM users AS u
JOIN excluded_group_names_replies eg ON eg.name = g.name
excluded_category_slugs AS (
SELECT unnest(string_to_array( :exclude_category_slugs, ',')) AS slug
excluded_categories AS (
SELECT id
FROM categories AS c
JOIN excluded_category_slugs ec ON ec.slug = c.slug
WHERE ec.slug = c.slug
restricted_topics AS (
SELECT
t.id,
t.created_at,
t.user_id
FROM
topics AS t
JOIN users u on u.id IN (SELECT id FROM impersonated_users)
JOIN user_stats AS us ON us.user_id = u.id
JOIN user_options AS uo ON uo.user_id = u.id
JOIN categories c ON c.id = t.category_id
LEFT JOIN topic_users tu ON tu.topic_id = t.id AND tu.user_id = u.id
WHERE
/** test **
AND t.created_at > (date_trunc('day', CURRENT_DATE) - INTERVAL '1 day' )
AND t.created_at < (date_trunc('day', CURRENT_DATE) )
** test **/
AND t.created_at > (date_trunc('month', CURRENT_DATE) - INTERVAL '1 year' )
AND t.archetype <> 'private_message'
AND t.deleted_at IS NULL
AND (t.visible OR u.admin OR u.moderator)
AND (
NOT c.read_restricted OR u.admin OR category_id IN (
SELECT c2.id FROM categories c2
JOIN category_groups cg ON cg.category_id = c2.id
JOIN group_users gu ON gu.user_id IN (SELECT id FROM impersonated_users)
AND cg.group_id = gu.group_id
WHERE c2.read_restricted
AND t.user_id NOT IN (SELECT id FROM excluded_users_topics)
AND t.category_id NOT IN (SELECT id from excluded_categories)
restricted_posts AS (
SELECT
p.id,
p.created_at
FROM
posts AS p
LEFT JOIN topics AS t ON p.topic_id = t.id
WHERE
/** test **
AND p.created_at > (date_trunc('day', CURRENT_DATE) - INTERVAL '1 day' )
AND p.created_at < (date_trunc('day', CURRENT_DATE) )
** test **/
AND p.created_at > (date_trunc('month', CURRENT_DATE) - INTERVAL '1 year' )
AND (
qualifying_topics AS (
SELECT
rt.id,
rt.created_at::date AS created_at,
MIN(p.post_number) AS first_reply,
COUNT(p) AS new_topic_posts
FROM
restricted_topics AS rt
LEFT JOIN posts p ON
p.topic_id = rt.id
AND p.deleted_at IS NULL
AND p.user_id != rt.user_id
AND p.user_id NOT IN (SELECT id FROM excluded_users_replies)
AND (
( :reply_within_x_days >= 0
AND p.created_at < ( rt.created_at::date + ( :reply_within_x_days + 1 ) )
OR
:reply_within_x_days < 0
AND to_char(date(p.created_at),'YYYY-MM') = to_char(date(rt.created_at),'YYYY-MM')
WHERE
rt.created_at > (date_trunc('month', CURRENT_DATE) - INTERVAL '1 year' )
GROUP BY rt.id, rt.created_at
topic_year_month_rate AS (
SELECT
to_char(date(tt.created_at),'YYYY-MM') as year_month,
COUNT(*) AS topics,
SUM(new_topic_posts) AS new_topic_posts,
SUM(CASE WHEN tt.first_reply IS NULL THEN 1 ELSE 0 END) AS no_response,
SUM(CASE WHEN tt.first_reply IS NOT NULL THEN 1 ELSE 0 END) AS response
FROM qualifying_topics AS tt
GROUP BY
year_month
ORDER BY
year_month
posts_year_month_rate AS (
SELECT
to_char(date(rp.created_at),'YYYY-MM') as year_month,
COUNT(*) as posts
FROM restricted_posts as rp
GROUP BY
year_month
ORDER BY
year_month
raw_year_month_rate AS (
SELECT
year_month,
SUM(posts) AS posts,
(SUM(posts) - SUM(new_topic_posts)) AS old_topic_posts,
SUM(topics) AS topics,
SUM(no_response) AS no_response,
SUM(response) AS response
FROM (
SELECT year_month, topics, 0 AS posts, new_topic_posts, 0 AS old_topic_posts, no_response, response FROM topic_year_month_rate
UNION ALL
SELECT year_month, 0 AS topics, posts, 0 AS new_topic_posts, 0 AS old_topic_posts, 0 AS no_response, 0 AS response FROM posts_year_month_rate
) AS combined
GROUP BY year_month
ORDER BY year_month
SELECT
rymr.*,
(CASE
WHEN topics <= 0 THEN 0
ELSE (
ROUND( (:pct_multiplier + 0.0) * (
(response * 1.0) / (topics * 1.0)
), :pct_places)
) END
) AS response_rate
FROM
raw_year_month_rate rymr
SELECT
FROM
year_months AS d
LEFT JOIN (
SELECT * FROM year_month_rate
) AS t USING (year_month)
ORDER BY
year_month
If you don’t want to use any exclusions just put a comma (,) in that input box.
So it should look a little like this:
So the columns are:
posts
- all qualifying posts from topics accessible to impersonated user after exclusion of both users and categories.
new_topic_posts
- posts made to topics created that month.
old_topic_posts
- posts made to topics created before that month.
topics
- all qualifying topics after exclusion of both users and categories.
no_response
- count of topics that didn’t receive a reply from that type of user
- e.g. a
staff member might have replied, but if you excluded staff it would be counted as no_response if that topic wasn’t created itself by an excluded user.
- a topic created by an excluded user is excluded anyway.
response
- count of topics that did receive a reply the month the topic was created from a non-excluded user.
response_rate
- percentage rate of response - higher the better
