Whenever I access the mobile app (iOS), it says “Authorize application access, you are not the correct trust level to access the user API”. If I tap on the Discourse logo, everything works just fine. I’m just wondering, what does it mean by user API? And what trust level to I have to be to access it?
The discussion revolves around the “Authorize application access” message encountered when using the Discourse mobile app on iOS. AIDoLS reports the issue, which is tied to the min trust level for user api key setting, defaulting to trust level 1. sam explains that new users are restricted by default but can be granted access by lowering the setting to 0. AIDoLS clarifies that access might be granted due to a higher trust level on another forum, as the setting is per-site. lenberg asks for the setting’s name, and sam confirms it and links to a related logout issue, noting it’s a known problem tied to Apple’s Safari. KDr2 shares a similar problem on the PyTorch forum, suspecting API access restrictions, and mentions difficulty deleting their GitHub-linked account. Falco inquires about the specific trust level setting on the PyTorch instance, which KDr2 confirms they don’t know, as they’re not an admin.
Yes, out-of-the-box, new users do not have access to the mobile app, they need to become trust level 1
There is a site setting that controls this restriction, you can bump it down to 0 if needed.
Huh. But I can use the mobile app. In fact, I’m using it right now.. Is it because I’m a higher trust level in a different forum on the same device?
Correct, the setting is per-site.
Ok. But does it not apply to the this forum?
What is the name of the setting?
We also get reports that users are logged out of the app over and over. Have you heard of this too?
The setting is min trust level for user api key set that to 0 to allow anyone access to that app.
Regarding logout see:
https://meta.discourse.org/t/report-of-user-unexpectedly-logged-out-iphone-safari/65761/2?u=sam
I wish I could fix it, you can somewhat mitigate, but until Apple properly fixes it there are no 100% reliable workarounds.
Does anyone know how to resolve this: https://discuss.pytorch.org/t/can-t-authorize-with-the-discoursehub-app-on-ios/56465 ?
I can’t access the PyTorch forum via DiscourseHub or Fig.
Thanks.
What is PyTorch configured min trust level for user api key ?
I don’t know, I am not an admin of that Discourse instance.
But I think I am an exception of the API accessing, I reached the “basic level” when I post that thread, and other users at the same level seem not to have that problem.
I tried to delete and recreate my account but failed to find a link to delete it (I am using GitHub account to log in) …
