Discourse 구독 플러그인의 Automatic_tax.enabled
Hello all,
I use the Stripe Discourse Sub plugin an got my first subscriber. yeah :slight_smile:
Unfortunatly the bill for this subscriber was without tax information, but which is necessary.
I had contact to the stripe support and they said:
I have looked at your Stripe Tax settings, Stripe Tax is configured correctly and automatic tax calculation is enabled.
However, “automatic_tax.enabled” is set to “false” (response text: line 6&7) and thus automatic tax calculation is not applied.
When creating a subscription, you must enable the automatic_tax parameter: https://stripe.com/docs/api/subscriptions/object#subscription_object-automatic_tax-enabled
The stripe support doesn’t know how the discourse plugin works or how to integrate this in the plugin. I have contact to the discourse team and they will have a look into it.
But it will help if more have this issue to made it work. :slight_smile:
3개의 좋아요
A possible solution is discussed here
2개의 좋아요
I already discoussed this with the discourse team and they said they will have look into it.
But no solution, yet.
To be percise: in my care there is no tax to be add to the price, the tax is already included and just have to bei show up in the bill.
1개의 좋아요
Solution is on the way:
4개의 좋아요
The subscription plugin now has support for the Stripe Pricing Table and Stripe Checkout
which allows for the proper tax collecting.
https://github.com/discourse/discourse-subscriptions/commit/45754baa0070f1fe600f4fd71d2d46e61d359b13
Once you setup your pricing table in stripe you can configure these settings in Discourse:
to start using Stripe Checkout for you subscribe page.
As part of the pricing table setup there is an option to enable automatic tax collecting
2개의 좋아요
This is great. Thank you very much. :smiling_face_with_three_hearts:
Does it also link to the pricing table if I klick on the Subscribe-Button on the campain banner? In my case this links to the “old” version. Just in the top menu it links to the pricing table.
1개의 좋아요
Oh, no it does not. I’ll make sure that works too!
1개의 좋아요
Done.
https://github.com/discourse/discourse-subscriptions/commit/542af4cf1665f9802da66831cbaa19c39b17f821
1개의 좋아요
Thx for that. Is this already live? Because it still works like it does yesterday. Do I have to do anything to change it to the “fixed” version?
I discovered another point: in the “old” version, if I have a subscription there is a mark on this one I already bought. In the new Version there is no mark which one I may already bought.
Is there an option to include this, that one can see which plan already is in use and to have a possibility to switch the plan?
This needs to be blank discourse subscriptions campaign product. And you might need to refresh your homepage?
That’s a good point. I don’t think that can be configured with Stripe Checkout because it doesn’t know anything about the user. Honestly I’m still thinking we need to keep adding functionality to the “old” way, as I’m not 100% convinced Stripe Checkout solves all of our problems. You definitely lose some customization like that, but I still like having it as an option for those who need it.
I know this is not what you are after, but a user can go to their billing page and see their active & canceled subscriptions now.
1개의 좋아요
Oh you need to have your site deployed! Sorry forgot to look at if you were hosted by us. I’ll let you know when that has been completed.
1개의 좋아요
It is.
I did several times, cleared the browser cache, tested it on a private browser window. The Subscribe button still links to /s instead auf s/subscriptions.
I agree. It was a nice to have option request. :slight_smile:
What I think it would be good: on the old way a have the possibility to add some text to discribe my plan (bullet point of included things etc.). In Stripe pricing table I do not have this option. So there are just the 2, 3 plan boxes which are a bit lost on the page. I think it would be nice to add some HTML/text above and below the embedded pricing table for a bit help and context.
1개의 좋아요
Great. Thanks. :slight_smile:
@SteveRueck k, you should be good to go now. :slight_smile:
1개의 좋아요
Now it is fine. Thx. :slight_smile:
1개의 좋아요
Good news!
There is now a Site Setting for automatic tax collecting discourse_subscriptions_enable_automatic_tax that you can enable. So that you can collect tax without having to use Stripe Checkout.
https://github.com/discourse/discourse-subscriptions/pull/218
If you enable it, but you have not configured your stripe instance properly to collect tax users may see this popup after completing the checkout process:
There is this guide for more info, but there shouldn’t be much do since the plugin is now passing in the appropriate automatic_tax[enabled]=true parameter (step 5).
Be sure you configure your registrations (step 4) as well:
Hi Blake,
that’s are great news. Thx.
I recently switched to the new checkout option and have now placed the corresponding, but also different, link everywhere. Is it possible to permanently redirect s/subscriptions to /s if one want to use the internal option?
It would be great if there is an automatic redirect if the option is disabled.
If I remove the checkout option, I get the message via s/subscriptions that there are currently no offers.
1개의 좋아요
Oh ya, totally, didn’t even think about this.
You should be able to manually setup a permalink for this in the meantime.
Sounds good. Thanks.
1개의 좋아요
FYI, it’s possible to add details to your Stripe product (Description, Marketing feature list) that then appear on your pricing table
For example, Stripe settings…
…appear like this in Discourse:
Hopefully that solves your need to differentiate products without further dev time on the Subscriptions plugin
1개의 좋아요
