אוטומציה של שדרוג Discourse והתוספים
Hi, I’m managing few instances of Discourse installed using this method with Docker discourse/docs/INSTALL-cloud.md at main · discourse/discourse · GitHub
I would like to automate upgrading forum version using Ansible, including Discourse plugins.
What commands do I need to execute?
Is this enough?
cd /var/discourse
./launcher rebuild
I’m not Ruby person and I want to ask before I break something :slight_smile:
לייק 1
Yes, just add git pull after the cd and that should work fine.
לייק 1
Awesome, it works, thanks :slight_smile:
cd /var/discourse
git pull
./launcher rebuild app
4 לייקים
The other thing you eventually need to worry about is Docker upgrades. Though that technically is covered by OS updates.
2 לייקים
This topic was automatically closed after 2960 days. New replies are no longer allowed.
