Avatares não são exibidos com uma porta personalizada
Hey, I’m from china. For some reason, port 80 is baned in China so I’m using a custom port to build Discourse.
But now I have some problem. I found that if I don’t use port 80, pictures or emoji will not show. So I turned to app.yml and I found the code likeDISCOURSE_HOSTNAME: discourse.example.com.
I edit that code into DISCOURSE_HOSTNAME: discourse.example.com:myPort, pictures and emoji show with no error, but avatars don’t show.
I don’t know how to fix that, Does anyone have met that problem?
Discourse only supports running at the default ports. You will need to proxy if you want it to go through different / non-standard ports.
3 curtidas
OK.Thank you, I will try that.
