AWS S3 והחשבון של יותר מ-1000 דולר ביום השני לאחר יצירתו
סיכום מבוסס בינה מלאכותית
An AWS S3 user reported receiving a $1,000 invoice on the second day despite having an empty bucket, due to costly unauthorized API calls targeting a commonly named bucket (e.g., “bucket-crap”). This vulnerability, dubbed “Denial of Wallet” (DoW), allows attackers to generate charges by repeatedly calling a bucket—even without access—since AWS currently bills for denied requests Rhod. AWS is investigating and plans to make unauthorized requests free of charge, covering HTTP 3xx/4xx status codes supermathie. While no Discourse sites using S3 for uploads have been reported affected maiki, users are advised to take precautions, such as using a CDN to obscure bucket names pfaffman. The situation is particularly concerning because, once an attack is detected, there is no way to stop it in real time supermathie. The issue highlights a critical billing risk for S3 users relying on default or predictable bucket names.
Post from an AWS S3 user, who on the second day had an invoice for $1000 dollars and it was empty.
Apparently the problem lies mainly in the bucket calls, which create a cost, but the problem was that this user created a bucket with a name like “bucket-crap”, said name was the one that came by default in an application, apparently widely used by companies.
However, all this revealed that this service could have a serious problem, since it could cause what they now call “DoW” “Denial of Wallet”, since any malicious user, knowing the name of said bucket could create thousands of calls to said bucket. bucket and create an exacerbated cost, because even if you do not have access to said bucket, calls to it, even if they are denied, generate a cost.
Detailed information in:
https://medium.com/@maciej.pocwierz/how-an-empty-s3-bucket-can-make-your-aws-bill-explode-934a383cb8b1
It appears AWS is looking into it:
I don’t think we’ve had a report of this happening with Discourse sites using S3 for uploads.
Indeed, I don’t think that’s the case, however it doesn’t hurt to take some precautions.
I guess that’s another reason that using a CDN is recommended, as it makes it harder, at least, to see the bucket name.
Indeed, I saw this as well and much cursing ensued.
Discourse is not designed to obscure the underlying uploads bucket name and in the intervening days have been hoping nobody used one of ours.
The worst thing is that even if you observe the attack, there is nothing you can do to stop it.
via Jeff Barr on Twitter: https://x.com/jeffbarr/status/1787844682216792163
Update: S3 engineers are working to make unauthorized requests that customers did not initiate free of charge.
This change will cover a range of HTTP 3xx/4xx status codes, including all of those cited in the article. We’re moving quickly and we plan to share more details this week.
