I’ve already read the threads that there’s often a problem with moving.
I’m just testing it, actually. And now I don’t know if maybe I’m doing something in a bad order?
the rake rebake post command returns 0 - so all posts are ok.
And now there’s a question. Maybe backup should be done after disconnecting from cdn? i.e. rebulld forum so that it does not use cdn and only then do the backup and move to another server?
I moved the page . And there are no pictures. I added “old” cdn. There were some pictures but only for a while (cache ? ) but later those pictures disappeared.
I added a new adress cdn2.domain . But it didn’t help.
So i deleted cdn. And now I’m checking by hand copying files with original images to the current folder.
I copied all the files, then I tried the command like this:
but it didn’t help, the pictures still don’t want to be restored.
That’s why I tried 3 more ways. So I set S3 and so I copied all images (original and optimized folder) (copy-paste) into bucket . But there is a problem because the rake migrate Migrating uploads to S3 for 'default'... rake aborted! command returns an error. eh…
