הגיבויים נשלחים ל-S3, אך עדיין נשמרים כמה גיבויים מקומיים אקראיים
סיכום מבוסס בינה מלאכותית
The user rahim123 discovered a significant amount of data in their local backup directory (/var/discourse/shared/standalone/backups/default/) despite configuring backups to S3. This data consists of several large backup files. The user suspects these may be failed backups, referencing a Discourse meta thread which suggests that these files should be automatically deleted according to their maximum backups policy. However, pfaffman notes that this is a long-standing bug and recommends manually deleting the local backups. omarfilip suggests changing the backup time, referencing another Discourse meta thread.
Hi there, I was checking my disk space and I found a significant amount of data in /var/discourse/shared/standalone/backups/default/ despite my backups being configured to s3.
3.6G Sep 15  2023 forum-com-2023-09-15-060642-v20230910021213.tar.gz
3.6G Sep 23  2023 forum-com-2023-09-23-060044-v20230910021213.tar.gz
3.7G Oct  7  2023 forum-com-2023-10-07-060258-v20230910021213.tar.gz
4.6G Mar  1 01:07 forum-com-2024-03-01-060255-v20240122015630.tar.gz
5.1G May 31 01:09 forum-com-2024-05-31-060527-v20240307231053.tar.gz
Would those be failed backups?
If that’s the case, it seems like they should be automatically deleted according to my maximum backups policy of 15 backups. Or maybe it’s happening because I have not set remove older backups ?
At any rate, I can manually delete them, right?
This is a long standing bug. I’ve been unable to figure out what causes it. It happens very rarely so it’s difficult to diagnose. The solution is to just delete the local backups.
Try changing your backup time.
