Bad gateway when trying to use SSL
Problem:
I have a DO server setup with a Wordpress site and Discourse. I have rencently made the move to SSL.
I went through and followed the guide here:
And the DO guide here
Either guide is giving me a bad gateway error when I try to go to SSL for the Discourse site.
My Setup:
Curently running NGINX 1.10.0 which is hosting my wordpress site (grimreapergamers.com) and proxy to my Discourse site (forums.grimreapergamers.com). I created two seperate certs through Let’s Encrypt. One for grimreapergamers.com and one for forums.grimreapergamers.com. My wordpress site is up and running with the cert today. When I try to change the NGINX config for the discourse site to use the cert I get a bad gateway error. Discourse is listening on port 85.
Here is my NGINX config for the discourse site. The commented out sever block is what is live today and working. The two blocks below are what I am trying to go to. Appreciate any guidance thanks.
I should point out that I have the http2 module loaded in NGINX which is why I am using that instead of SPDY.
Got it working.
Figured out my issue. Also merged into single cert. Don’t know why I thought I needed two. Also moved off port 85. figured that was not a good one to be using.
My working config
http://pastebin.com/FUPBzkiK
