בעיית תמונה חסרה בתג
סיכום מבוסס בינה מלאכותית
The user f1r4s reports an issue with missing badge images after restoring a backup, receiving a NoMethodError related to image_url. The error occurs because the badge images are not properly linked or restored. cocococosti suggests verifying that the images were included in the backup and checking the badges and uploads tables to confirm the image IDs and file paths. They recommend using the Data Explorer plugin to inspect the badges table, though f1r4s notes they couldn’t find the badge table. Ihor_Shevchenko asks if the issue was resolved, and JammyDodger references a related fix in another topic.
Hello,
I have issue with badge section, i have modified some badges and add some images there; after 6 months i restore a backup and everything works fine execpt the badge section; i try to login with safe-mode and disable all plugins… but issue still same, how can i restore the badge sections withd default name and images ?
error show me
Message (2 copies reported)
NoMethodError (undefined method `url' for nil:NilClass)
app/models/badge.rb:306:in `image_url'
(eval):10:in `_fast_attributes'
app/controllers/application_controller.rb:484:in `serialize_data'
app/controllers/badges_controller.rb:30:in `index'
app/controllers/application_controller.rb:387:in `block in with_resolved_locale'
app/controllers/application_controller.rb:387:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:71:in `call'
lib/middleware/anonymous_cache.rb:356:in `call'
config/initializers/100-quiet_logger.rb:23:in `call'
config/initializers/100-silence_logger.rb:31:in `call'
lib/middleware/enforce_hostname.rb:23:in `call'
lib/middleware/request_tracker.rb:198:in `call'
Backtrace
active_model_serializers (0.8.4) lib/active_model/serializer.rb:99:in `block in attribute'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:468:in `rescue in attributes'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:455:in `attributes'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:480:in `_serializable_hash'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:359:in `serializable_hash'
active_model_serializers (0.8.4) lib/active_model/array_serializer.rb:89:in `block in _serializable_array'
active_model_serializers (0.8.4) lib/active_model/array_serializer.rb:79:in `map'
active_model_serializers (0.8.4) lib/active_model/array_serializer.rb:79:in `_serializable_array'
Env
HTTP HOSTS: site.com
Other images were restored correctly?
Did you make sure to include uploads in the backup?
Are you using s3 to store your uploads? If not, could you enter the container, and go to /shared/uploads/default/original/1X do you have files there?
yes i don’t use s3, and i always use to include attachment pictures in backup…
what i’m looking for now how to make reset for badge images ??
Out of the box, there is no way to “make reset for badge images” that I know of.
What I’d do first is check that the badges missing images were at least restored. If you check the badges table you can get the ID of the image at the image_upload field. Then use that ID in the uploads table, to get the URL of the image, like so:
select url from uploads where id = <badge-upload-id>
The URL looks something like this: /uploads/default/original/1X/c1325294cd04ae6e9072a2577543dad66cf31afe.jpeg and from there, you can extract the name of the file, in this case it would be c1325294cd04ae6e9072a2577543dad66cf31afe.jpeg
Then you can check in the server that the image is there with find or whatever method you prefer
cd /
Once you made sure the images were restored, at the right path, then you can continue debugging as the issue is somewhere else.
The version of Discourse from the backup is too different from the version of Discourse you are restoring into?
Maybe someone else in the community knows more about this, though.
Perfect, but how can i know the missing badge url or name ?
I cannot find how i know the missing url or badge image name.
Follow the instruction here Discourse Data Explorer to install the data explorer plugin, you can use it to inspect the badges table. Focus on your custom badges.
I did install it; but i didn’t find the badge table;
this is the error i get when i open the profile of administrator;
Message
lib/freedom_patches/ams_include_without_root.rb:54:in `include!'
app/controllers/users_controller.rb:92:in `block (2 levels) in show'
app/controllers/users_controller.rb:89:in `show'
Backtrace
active_model_serializers (0.8.4) lib/active_model/serializer.rb:448:in `block in merge_association'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:445:in `each'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:445:in `merge_association'
Env
Hi @f1r4s
I faced the same problem. Did you manage to solve this problem?
I believe this was resolved in this topic:
