I am attempting to build a plugin that allows badges to be created via a user interface, much like what was requested on this post:
I have built what I think is the necessary logic and structure into the plugin, but for some reason there continues to be an issue with routes.rb and duplicate routes.
The git is here:
This is the error I’m getting, which includes a port error, which may be a separate issue:
> 1861:M 02 Oct 2024 15:32:58.660 # Failed listening on port 6379 (TCP), aborting.
> I, [2024-10-02T15:33:08.619145 #1] INFO -- :
> I, [2024-10-02T15:33:08.622660 #1] INFO -- : > cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate'
> Plugin name is 'badge maker', but plugin directory is named 'badgemaker'
> rake aborted!
> ArgumentError: Invalid route name, already in use: 'unique_badge_maker_plugin' (ArgumentError)
> You may have defined two routes with the same name using the `:as` option, or you may be overriding a route already defined by a resource with the same naming. For the latter, you can restrict the routes created with `resources` as explained here:
> https://guides.rubyonrails.org/routing.html#restricting-the-routes-created
> raise ArgumentError, "Invalid route name, already in use: '#{name}' \n" \
