בקרים ונתיבים
When following the tutorial for setting up a custom controller and route, I get the Routing Error page. The page lists the paths and controllers, which is all correct however, when I request the resource, I get errors. I understand this is an old tutorial but, is the information accurate? I’ve attached my plugin skeleton and maybe someone can help trouble shoot the issue. Thanks!
jb-test.zip (522.2 KB)
I think the thing you’re missing is to add it to rails routing.
Something like this in plugin.rb.
  JbTest::Engine.routes.draw do
    get "/hello" => "jbtest#index"
Here’s a start. The other thing to do is to get GitHub - discourse/all-the-plugins and look through there. Now that so many have been added to core, though, I suppose you could just look there for examples of added to the Rails route.
Minimal Custom Route Plugin for Discourse AI
pfaffman:
what’s needed to add a route to Discourse rails?
Can you give me a minimal proof of concept that includes a plugin.rb, and controller, and the stuff needed to add the route to rails?
DiscourseHelper:
Searching
Searching for: How to add a custom route to Discourse using a plugin, including a minimal example with plugin.rb, custom controller, and the necessary code to register the Rails route?
Reading
Read: Developing Discourse Plugins - Part 1 - Create a basic plugin
Searching
Searching for: Minimal proof of concept for adding a custom Rails route in Discourse plugin including plugin.rb, controller implementation, and code to register the route.
Reading
Read: Creating Routes in Discourse and Showing Data
Reading
Read: Add custom user routes using plugins
Reading
Read: Adding a ruby controller via plugin
Here’s a minimal proof of concept for adding a custom Rails route to Discourse via a plugin, including the key files you’ll need: plugin.rb, a controller, and the code for registering the route.
Key Points
  • The best practice is to use a Rails “engine” within your plugin to isolate your controllers and routes.
  • You need to explicitly require your controller in plugin.rb.
  • To register a new route, you use the engine’s routes.draw method and mount the engine in the main application routes.
Minimal Example
plugin.rb
# name: my-custom-route
# about: Adds a custom route via Rails engine in a plugin
# version: 0.1
# authors: Your Name
after_initialize do
  module ::MyPlugin
    class Engine < ::Rails::Engine
      engine_name "my_plugin"
      isolate_namespace MyPlugin
  require_dependency File.expand_path('../app/controllers/my_plugin/my_controller.rb', __FILE__)
  MyPlugin::Engine.routes.draw do
    get "/hello" => "my#hello"
  Discourse::Application.routes.append do
    mount ::MyPlugin::Engine, at: "/my_plugin"
module MyPlugin
  class MyController < ::ApplicationController
    def hello
      render plain: "Hello from my plugin!"
How this works:
  • GET /my_plugin/hello will return the plain text response "Hello from my plugin!".
Required Directory Structure:
plugins/
  my-custom-route/
    plugin.rb
    app/
      controllers/
        my_plugin/
          my_controller.rb
For more details and expanded examples, see:
This proof of concept will help you add a simple custom endpoint to your Discourse instance via a plugin. If you have questions about integrating this with Ember/JS side, let me know!
בסדר. תודה. נראה שהקטע הזה של הקוד נוסף ל-routes.rb, אבל אני אעבור על התוספים הראשיים ואראה אם אני מוצא דוגמה ב-plugins.rb. תודה!
