The “Help Desk” badge is not working as expected. Users with 10 accepted answers are not receiving the badge. zainab shared the SQL code, but dax pointed out that the original code had a HAVING COUNT(*) > 9 line to count the number of accepted answers, which was missing in the shared code. zainab thanked dax and agreed to make the change. Separately, SidV encountered an error with the code, but solved the issue by referencing a related discussion on Meta Discourse (https://meta.discourse.org/t/10-accepted-answer-badge-giving-an-error/34560/3?u=sidv).
I’m not sure if I’m posting in the correct category.
anyway theres a badge for the forum called help desk and its not working, users get 10 accepted answers yet they dont get a badge
here’s the SQL code:
SELECT p.user_id, p.id post_id, p.updated_at granted_at
FROM badge_posts p
WHERE p.post_number > 1 AND
p.id IN (
SELECT post_id FROM (
SELECT pc.post_id, row_number()
OVER (PARTITION BY p1.user_id ORDER BY pc.created_at) as rnum
FROM post_custom_fields pc
JOIN badge_posts p1 ON p1.id = pc.post_id
JOIN topics t1 ON p1.topic_id = t1.id
WHERE name = 'is_accepted_answer' AND
p1.user_id <> t1.user_id AND
:backfill OR
p1.user_id IN (
select user_id from posts where p1.id IN (:post_ids)
) X WHERE rnum = 1)
I don’t know if the query change in the meanwhile but the original code is this:
SELECT id user_id, current_timestamp granted_at
FROM users
WHERE id IN (
SELECT p1.user_id
WHERE p1.user_id <> t1.user_id AND
p1.user_id IN (
SELECT user_id
FROM posts
WHERE :backfill OR p1.id IN (:post_ids)
GROUP BY p1.user_id
HAVING COUNT(*) > 9
e.g. in your code I don’t see the line “HAVING COUNT” for count the number of accepted answers
EDIT: @zee the code you paste in your post is for 1 accepted answer, not for 10
