Erreur SQL Badge : q.user_id
Bonjour !
Je travaille sur la création d’un badge pour les personnes dont le message a été marqué comme solution via le plugin « solutions checkbox ». Voici la requête SQL :
SELECT
       u.username AS "username",
       count(*) AS "count_received_best_answer",
       current_timestamp granted_at
FROM
       notifications n
JOIN
       users u ON n.user_id = u.id
JOIN
       topics t ON n.topic_id = t.id
JOIN
       categories c ON t.category_id = c.id
WHERE
       n.notification_type = 14 AND
       n.data LIKE '%solved.accepted_notification%' AND
       n.created_at > CURRENT_DATE - INTERVAL '30 days'
GROUP BY u.username
HAVING count(*) > 0
ORDER BY count(*)
Cependant, lorsque j’essaie d’apercevoir le badge, je reçois cette erreur :
Après avoir cherché ici, je comprends que q.user_id est un champ en arrière-plan de ces tâches de badge, mais je ne parviens pas à comprendre pourquoi je rencontre cette erreur. Toute aide serait appréciée !
Your query needs to return at least the following columns:
  • user_id
  • granted_at
Also, you should definitely take a look at Add Badge to Solve answer - #2 by dax. :wink:
YES. That was all I needed. Not sure why staring at it for four hours did not make it obvious. thanks much @gerhard
How does this differ from the Add Badge to Solve answer topic? I am looking to do the same thing but unsure if either one would be applied for every solution or a set number?
