(Basic) Toolbar Customisation
The toolbar has grown a lot over the years, and not everyone uses all of it. If you write in Markdown by hand, or you never touch the text-size menu, a user can now just turn those off for themselves.
How to try it
  1. Go to Admin → Upcoming Changes at /admin/config/upcoming-changes
  2. Find Composer toolbar customization and enable it
  3. Then, as any member: Preferences → Interface → Composer toolbar
  4. Untick anything you don’t want and save
You can turn it off again at any time from the same place.
What you can hide
Bold, italic, text sizes, link, blockquote, code, lists, emoji, GIF, post language, and toggle direction.
Some of these only appear if the matching site setting is on — GIFs, emoji, text direction and post language will only be listed if your site has them enabled.
What you can’t hide
The upload button and the + menu always stay. The + menu is how plugins like polls, dates, details and math add their features to the composer, so hiding it would cut off access to those entirely.
Buttons added by plugins also stay put. If your admin has enabled something that adds to the composer, the reasoning is that it’s there on purpose.
Worth knowing
Keyboard shortcuts keep working. Hiding the bold button doesn’t disable Ctrl+B. This is deliberate — for a lot of people the button is the thing they don’t need, not the shortcut.
It’s per account, not per device. Your choices follow you between desktop and mobile rather than being set separately on each.
Composer needs reopening. If you change the setting while a composer is already open, reopen it to see the change.
What’s not in this version
  • No reordering. You can hide buttons, not rearrange them.
  • Items in the + menu can’t be hidden.
  • No moving items between bar and + menu
All of the above are great ideas (and may be(come) popular requests), but add complexity.
Love this! Sometimes the simplest changes are the best.
How does this affect items in the more menu or items added by components? Do items move out from the more menu to the main toolbar if too little are selected?
No, as covered by:
Not manual, not automatic.
Giving it a shot! I’ve got “blockquote” and “insert gif” enabled. Disabled the rest.
This is great, though i was actually looking for a way to simplify the toolbar.
It looks like this could also be a way for admins to change the default settings for all users, but still allow more options for those who want it.
I wanted to remove/hide the Wrap function. Because no user knows what it is, and even searching meta doesn’t very easily result in an answer.
Could you consider allowing items from the extras drop down, specifically templates, to be pinned to the composer toolbar? And ideally, the ability to do this globally from the admin settings. Thanks.
Thank you! I love this. I’ve removed a number of default menus items so I no longer have to scroll right to the + menu. So very helpful.
Wait, is this an option? I saw this pop up but then got less excited when I realized this is just for the individual, not global. I’d really like to be able to globally set the default composer toolbar icons…so is that possible with this?
It isn’t at the moment, no. I think that this is better suited as a personal user choice, than an admin deciding for everyone. But I’m open to hearing a counter argument.
I think an admin configuring a default that matches the general idea of the community is fine. Similar to the categories and tag sections of the sidebar where admins can configure a default and users can still change it to make it fit even better for them.
Most user preferences have a default that can be configured by admins to offer something that will be a good fit for most members.
Exactly this. Let the admins select the default but still let regular users adjust as well to their personal liking.
Non-technical users would appreciate the admin decision and taste, and technical users would love to choose which icons/actions are allowed in their own interface.
I wonder if a default that doesn’t contain the “Label AI content” option would have worked for Improved AI content labelling in the composer for post content - #29 by martin, or if admins should be allowed to block options so users cannot choose them, and provide defaults.
But I like the idea of one setting for all options instead of separate ones.
I had the same reaction. Seemed obvious that an admin would want an easy way to set the default. Then, this feature has the potential to make the first user experience a little less overwhelming. Yet still allow returning users to explore more options themselves.
