It seems I got an issue with our custom language (tested Multilingual a couple of months before and I get some issues with tags too).
- When I try to move custom language to ES, I get the following:
PG::UniqueViolation: ERROR: duplicate key value violates unique constraint "index_translation_overrides_on_locale_and_translation_key"
DETAIL: Key (locale, translation_key)=(es, js.docs.categories) already exists.
- Similar behavior when I try to export customized text to a file:
./launcher enter app
bin/rake export:translation_overrides
Returns:
rake aborted!
ActiveRecord::NoDatabaseError: We could not find your database: discourse. Which can be found in the database configuration file located at config/database.yml
I can’t use Discourse Translator w/DeepL what was working for another users.
I have an issue updating trust_levels strings, very probably related to this.
/logs shows the following (related to Location plugin that I disabled and issue persist):
NoMethodError (undefined method `custom_fields' for nil:NilClass)
(eval):93:in `_fast_attributes'
app/serializers/post_stream_serializer_mixin.rb:54:in `block in posts'
app/serializers/post_stream_serializer_mixin.rb:47:in `map'
app/serializers/post_stream_serializer_mixin.rb:47:in `posts'
app/serializers/post_stream_serializer_mixin.rb:18:in `post_stream'
(eval):3:in `_fast_attributes'
app/controllers/topics_controller.rb:1245:in `block (2 levels) in perform_show_response'
app/controllers/topics_controller.rb:1239:in `perform_show_response'
app/controllers/topics_controller.rb:187:in `show'
app/controllers/application_controller.rb:418:in `block in with_resolved_locale'
app/controllers/application_controller.rb:418:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:74:in `call'
lib/middleware/anonymous_cache.rb:367:in `call'
config/initializers/100-quiet_logger.rb:20:in `call'
config/initializers/100-silence_logger.rb:29:in `call'
lib/middleware/enforce_hostname.rb:24:in `call'
lib/middleware/request_tracker.rb:228:in `call'
plugins/discourse-nationalflags/plugin.rb:51:in `block (2 levels) in activate!'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:468:in `rescue in attributes'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:455:in `attributes'
plugins/discourse-custom-wizard/lib/custom_wizard/extensions/custom_field/serializer.rb:4:in `attributes'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:480:in `_serializable_hash'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:359:in `serializable_hash'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:347:in `as_json'
activerecord (7.0.4.3) lib/active_record/relation/delegation.rb:88:in `each'
activesupport (7.0.4.3) lib/active_support/json/encoding.rb:22:in `encode'
activesupport (7.0.4.3) lib/active_support/core_ext/object/json.rb:42:in `to_json'
active_model_serializers (0.8.4) lib/active_model/serializer.rb:331:in `to_json'
multi_json (1.15.0) lib/multi_json/adapters/oj.rb:56:in `dump'
multi_json (1.15.0) lib/multi_json/adapter.rb:25:in `dump'
multi_json (1.15.0) lib/multi_json.rb:139:in `dump'
actionpack (7.0.4.3) lib/action_controller/metal/mime_responds.rb:214:in `respond_to'
actionpack (7.0.4.3) lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack (7.0.4.3) lib/abstract_controller/base.rb:215:in `process_action'
actionpack (7.0.4.3) lib/action_controller/metal/rendering.rb:53:in `process_action'
actionpack (7.0.4.3) lib/abstract_controller/callbacks.rb:234:in `block in process_action'
activesupport (7.0.4.3) lib/active_support/callbacks.rb:118:in `block in run_callbacks'
plugins/discourse-staff-alias/plugin.rb:105:in `block (4 levels) in activate!'
activesupport (7.0.4.3) lib/active_support/callbacks.rb:127:in `instance_exec'
activesupport (7.0.4.3) lib/active_support/callbacks.rb:127:in `block in run_callbacks'
i18n (1.12.0) lib/i18n.rb:322:in `with_locale'
plugins/discourse-multilingual/extensions/application_controller.rb:8:in `with_resolved_locale'
activesupport (7.0.4.3) lib/active_support/callbacks.rb:138:in `run_callbacks'
actionpack (7.0.4.3) lib/abstract_controller/callbacks.rb:233:in `process_action'
actionpack (7.0.4.3) lib/action_controller/metal/rescue.rb:22:in `process_action'
actionpack (7.0.4.3) lib/action_controller/metal/instrumentation.rb:67:in `block in process_action'
activesupport (7.0.4.3) lib/active_support/notifications.rb:206:in `block in instrument'
activesupport (7.0.4.3) lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport (7.0.4.3) lib/active_support/notifications.rb:206:in `instrument'
actionpack (7.0.4.3) lib/action_controller/metal/instrumentation.rb:66:in `process_action'
actionpack (7.0.4.3) lib/action_controller/metal/params_wrapper.rb:259:in `process_action'
activerecord (7.0.4.3) lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack (7.0.4.3) lib/abstract_controller/base.rb:151:in `process'
actionview (7.0.4.3) lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler (3.1.0) lib/mini_profiler/profiling_methods.rb:85:in `block in profile_method'
actionpack (7.0.4.3) lib/action_controller/metal.rb:188:in `dispatch'
actionpack (7.0.4.3) lib/action_controller/metal.rb:251:in `dispatch'
actionpack (7.0.4.3) lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
actionpack (7.0.4.3) lib/action_dispatch/routing/route_set.rb:32:in `serve'
actionpack (7.0.4.3) lib/action_dispatch/journey/router.rb:50:in `block in serve'
actionpack (7.0.4.3) lib/action_dispatch/journey/router.rb:32:in `each'
actionpack (7.0.4.3) lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack (7.0.4.3) lib/action_dispatch/routing/route_set.rb:852:in `call'
rack (2.2.7) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.7) lib/rack/conditional_get.rb:27:in `call'
rack (2.2.7) lib/rack/head.rb:12:in `call'
actionpack (7.0.4.3) lib/action_dispatch/http/permissions_policy.rb:38:in `call'
rack (2.2.7) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.7) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (7.0.4.3) lib/action_dispatch/middleware/cookies.rb:704:in `call'
actionpack (7.0.4.3) lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
activesupport (7.0.4.3) lib/active_support/callbacks.rb:99:in `run_callbacks'
actionpack (7.0.4.3) lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack (7.0.4.3) lib/action_dispatch/middleware/debug_exceptions.rb:28:in `call'
actionpack (7.0.4.3) lib/action_dispatch/middleware/show_exceptions.rb:26:in `call'
logster (2.12.2) lib/logster/middleware/reporter.rb:43:in `call'
railties (7.0.4.3) lib/rails/rack/logger.rb:40:in `call_app'
railties (7.0.4.3) lib/rails/rack/logger.rb:27:in `call'
actionpack (7.0.4.3) lib/action_dispatch/middleware/remote_ip.rb:93:in `call'
actionpack (7.0.4.3) lib/action_dispatch/middleware/request_id.rb:26:in `call'
rack (2.2.7) lib/rack/method_override.rb:24:in `call'
actionpack (7.0.4.3) lib/action_dispatch/middleware/executor.rb:14:in `call'
rack (2.2.7) lib/rack/sendfile.rb:110:in `call'
actionpack (7.0.4.3) lib/action_dispatch/middleware/host_authorization.rb:131:in `call'
rack-mini-profiler (3.1.0) lib/mini_profiler.rb:260:in `call'
message_bus (4.3.2) lib/message_bus/rack/middleware.rb:60:in `call'
railties (7.0.4.3) lib/rails/engine.rb:530:in `call'
railties (7.0.4.3) lib/rails/railtie.rb:226:in `public_send'
railties (7.0.4.3) lib/rails/railtie.rb:226:in `method_missing'
rack (2.2.7) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.7) lib/rack/urlmap.rb:58:in `each'
rack (2.2.7) lib/rack/urlmap.rb:58:in `call'
unicorn (6.1.0) lib/unicorn/http_server.rb:634:in `process_client'
unicorn (6.1.0) lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn (6.1.0) lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn (6.1.0) lib/unicorn/http_server.rb:143:in `start'
unicorn (6.1.0) bin/unicorn:128:in `<top (required)>'
vendor/bundle/ruby/3.2.0/bin/unicorn:25:in `load'
vendor/bundle/ruby/3.2.0/bin/unicorn:25:in `<main>'
How can I get more deep into logs to see what’s happening?
What’s the more efficient method to save our custom language modifications and use default ES again? That probably fix the general issue.
