Best practices for managing image uploads in product-heavy community discussions
סיכום מבוסס בינה מלאכותית
The discussion centers on best practices for managing image uploads in product-heavy community forums. vedansh_industries asks about optimal image size, compression, external hosting (e.g., S3), performance considerations, and moderation strategies. pfaffman responds that default settings are generally sufficient, external hosting is advisable for large-scale uploads with technical support, and performance issues can typically be managed without intervention. They also suggest deferring moderation efforts until actual problems arise.
Hello everyone,
I wanted to ask for some guidance on handling image uploads efficiently in communities where users frequently share product-related images.
In some industries, discussions involve multiple images such as surface textures, material finishes, or usage examples. Over time, this can increase storage usage and also impact page load performance if not managed properly.
I’m interested in understanding:
• Recommended image size and compression settings
• Whether external image hosting is preferred over local uploads
• Best practices to maintain performance without limiting discussion quality
• Any moderation tips for handling large numbers of attachments
Would love to hear how other community managers or Discourse admins handle uploads in image-heavy discussions.
Thanks in advance.
The defaults should work.
If you’re going to have lots of uploads and/or have a competent technical person to set up S3, then that’s recommended.
You shouldn’t need to do anything.
Until you see actual problems, I’d not try to solve them.
