صفحة رئيسية فارغة في أحد المنتديات (مجلد فرعي + تثبيت متعدد المواقع)
Hello,
My issue is related to this thread that has been previously closed
Despite upgrading with the patch provided by @david, I still encounter the issue on one forum out of two (on a multisite install).
https://www.dolibarr.org/forum correctly redirects to https://www.dolibarr.org/forum/
but
https://www.dolibarr.fr/forum does not redirect to https://www.dolibarr.fr/forum/ and thus I am getting a blank page.
Discourse has been setup using Serve Discourse from a subfolder (path prefix) instead of a subdomain and we are using a multi container docker setup (web_only and data).
Some other things that I have observed is that on https://www.dolibarr.org/forum/, when opening the main hamburger menu, the FAQ link is now on top of the menu whereas on https://www.dolibarr.fr/forum/, it remains on the bottom (I do not understand why and my understanding is that when updating changes normally applies to all forums on a multisite install).
I would appreciate any help :blush:
إعجابَين (2)
Anything else to do here @david?
إعجابَين (2)
I’m encountering a similar issue (here)
إعجاب واحد (1)
Thanks for reporting this @jtraulle, it should be fixed by this commit which will hit tests-passed in the next hour.
For the working case, your proxy is adding the trailing slash via a 301 redirect, so it avoided the bug in Discourse
$ curl -I https://www.dolibarr.org/forum
HTTP/2 301
3 إعجابات
Thanks, you are right did not think about this but this make sense (another sysadm have added a rewrite rule on the Apache2 proxy side for the working forum :stuck_out_tongue_winking_eye: ).
RewriteRule ^/forum$ /forum/ [L,R=permanent]
Thanks a lot, will upgrade and let you know :slight_smile:
3 إعجابات
Thanks @david, I have applied the update and it is OK :slight_smile:
:+1: :medal_sports:
3 إعجابات
