See title. I am in a bit of a pickle now. I am trying to roll back to a pre-Ember 5 build of Discourse to maintain legacy long term service support for my forum, which relies on plugins that have now been rendered inoperable under the new Discourse release. To roll back the clock by a few days, I have cleared everything away (destroyed the container and blew away /var/discourse and repulled from GitHub) and I am starting afresh with a pristine Discourse installation. In my .yml, I have specified “version: beta” so I should be pre-Ember 5.
After I do the usual of setting up my admin account and verifying it, I am presented with an endless loading screen. And yes, I also go into safe mode view and enable Force HTTPS as I always do with my setup.
I have even tried every which way, removing plugins, and even starting afresh with no plugins except the absolute minimum of just…
… in my .yml file. No dice. After setting up my admin account, I am still (barebones pristine install) presented with an endless loading screen of death.
Looking at the console, this is what I am seeing currently:
Here is my current .yml file:
## this is the all-in-one, standalone Discourse Docker container template
## After making changes to this file, you MUST rebuild
## BE *VERY* CAREFUL WHEN EDITING!
## YAML FILES ARE SUPER SUPER SENSITIVE TO MISTAKES IN WHITESPACE OR ALIGNMENT!
## visit http://www.yamllint.com/ to validate this file as needed
templates:
#- "templates/web.ssl.template.yml"
#- "templates/web.letsencrypt.ssl.template.yml"
## which TCP/IP ports should this container expose?
## If you want Discourse to share a port with another webserver like Apache or nginx,
## see https://meta.discourse.org/t/17247 for details
expose:
- "10080:80" # http
- "10443:443" # https
params:
db_shared_buffers: "2048MB"
#db_work_mem: "40MB"
version: beta
## Maximum upload size (default: 10m)
upload_size: 8196m
env:
LANG: en_US.UTF-8
UNICORN_WORKERS: 8
## Required. Discourse will not work with a bare IP number.
DISCOURSE_HOSTNAME: forum.tabletpc.review
## Uncomment if you want the container to be started with the same
## hostname (-h option) as specified above (default "$hostname-$config")
#DOCKER_USE_HOSTNAME: true
DISCOURSE_DEVELOPER_EMAILS: 'admin@tabletpc.review'
## TODO: The SMTP mail server used to validate new accounts and send notifications
# SMTP ADDRESS, username, and password are required
# WARNING the char '#' in SMTP password can cause problems!
DISCOURSE_SMTP_ADDRESS: [REDACTED]
DISCOURSE_SMTP_PORT: 587
DISCOURSE_SMTP_USER_NAME: [REDACTED]
DISCOURSE_SMTP_PASSWORD: " [REDACTED]"
#DISCOURSE_SMTP_ENABLE_START_TLS: true # (optional, default true)
## If you added the Lets Encrypt template, uncomment below to get a free SSL certificate
#LETSENCRYPT_ACCOUNT_EMAIL: me@example.com
## The CDN address for this Discourse instance (configured to pull)
## see https://meta.discourse.org/t/14857 for details
#DISCOURSE_CDN_URL: //discourse-cdn.example.com
DISCOURSE_MAXMIND_LICENSE_KEY: [REDACTED]
volumes:
- volume:
host: /var/discourse/shared/tabletpcreview
guest: /shared
- volume:
host: /var/discourse/shared/tabletpcreview/log/var-log
guest: /var/log
## Plugins go here
hooks:
after_code:
- exec:
cd: $home/plugins
cmd:
run:
EDIT: Oddly enough, if I disable plugins in safe mode, the site works. However, if I leave them enabled, it does not. My only plugin is Docker Manager, so why is it failing to load?
This works: https://forum.tabletpc.review/?safe_mode=no_plugins
This does not work: https://forum.tabletpc.review/?safe_mode=no_themes
