"blocked onebox domains" doesn't work
I put youtube.com in the “blocked onebox domains” setting. Then made a post with a youtube link. A onebox showed up. The expected behavior is no onebox preview. That should be reproducible.
Also there is no one way to disable onboxes globally that I can see. This is really annoying. One obvious way to allow this would be for “blocked onebox domains” to support *. If the main bug gets fixed, I suggest doing that along with it.
I am unable to reproduce this. Is the link in the form of https://www.youtube.com/watch?v=XXXX ? You might want to block youtu.be as well.
Just set max_oneboxes_per_post to 0.
Thank you. This works. I should have noticed this.
Yes, it is in that form.
Ok. I’ve done a bit more experimenting, and the issue only shows up for domains which have already had a link preview generated. So, if you create a new post, paste in a link to domain X, which generates a link preview box, (don’t even complete the post) then block the domain, then create a new post, paste in the same link, the link preview is generated despite it being blocked.
Additional info: version I tested on: Discourse 2.9.0.beta7 - GitHub - discourse/discourse: A platform for community discussion. Free, open, simple. · GitHub version 5894e7d30f2c597b9750f6b6a55d81f9d101c037
Yep, seems like the cache is checked before the blocklist is checked: discourse/lib/final_destination.rb at main · discourse/discourse · GitHub
I’ve just encountered this problem too and it is quite an annoying bug.
Doesn’t this mean that those should be switched around?
