Board unaccessible after upgrade
The discussion revolves around a user’s issue with their Discourse board becoming inaccessible after an upgrade. Saiano reports that despite a successful update, the app fails to start. JammyDodger suggests trying safe mode and checking the logs, but Saiano confirms the issue persists in safe mode.
JammyDodger suspects a plugin issue, specifically with the retort plugin, which Saiano confirms is installed. JammyDodger provides a link to a relevant Meta Discourse topic and advises removing the plugin from the app.yml file, which Saiano confirms resolves the issue.
Hifihedgehog adds that an alternative solution is to manually enable Ember 3 compatibility mode in the app.yml file, but notes that this will eventually be deprecated in Q1, according to Discourse.
I’ve just update my board, getting no errors, but accessing the site, the app doesn’t start
Droplet on digital ocean, any suggestions?
I’ve tried to rebuild, but nothing changes.
Could you try safe mode and see if that helps? Also, there may be more information in your /logs or your browser console that may help narrow it down.
Same problem in safe mode. I’ll check logs
Hmm. If you get the same in safe mode then it might be a plugin with deeper roots than safe mode disables. Do you have a list of ones you have installed?
discourse-spoiler-alert.git
discourse-cakeday.git
retort.git
Ah, I think it may be retort:
If you could remove that from your app.yml and rebuild hopefully everything should come good. :crossed_fingers:
Thank you, this solved the problem.
Great! Alternatively, Ember 3 can still be manually enabled via a flag in your app.yml file if you have a need in your user base to preserve Retort functionality. Per Discourse, however, that flag will eventually not work as the Ember 3 compatibility mode will be gutted entirely. The ETA of that I last read was Q1 so in the next couple months or sooner, that fallback compatibility mode will be deprecated.
